HVAC Heat Duct Location - HVAC - DIY Chatroom Home Improvement Forum
Old 03-19-2012, 10:48 AM   #1
Hey,
I'm remodelling my basement and I'm torn between where to locate the heat vent and return duct.
In winter times, the heat vent located near ground will provided more efficient heating as hot air rises. However, in summer it may be better to have the vent on the ceiling of the basement since cold air (AC) drops.
What do you guys think?
GeorgesAA is offline   Reply With Quote
Old 03-19-2012, 03:42 PM   #2
An old Tradesmen
Rewards Points: 7,786
6 one way half a dozen the other.
Place the supplies high, and use registers that throw the air down to the floor.
What is this HVAC Heat Pump System - Water Pipes To Indoor Coil? kentkeith HVAC 20 01-17-2011 04:07 AM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 12:19 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 08:22 PM
Duct work re-design for Heat Pump addition zootjeff HVAC 8 07-21-2009 04:19 AM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
