HVAC - Hard-Start Device - HVAC - DIY Chatroom Home Improvement Forum
Old 01-06-2009, 08:12 PM   #1
Rewards Points: 502
So what is the difference between a "hard-start" kit and one just increasing the capacity of the existing start capacitor for a compressor?
What I am reading, it almost appears that all a hard-start kit is is a 2nd capacitor hooked parallel with ones existing capacitor.
So my thought was to just swap out my existing cap with a larger one.
Thoughts?
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 01-06-2009, 08:33 PM   #2
An old Tradesmen
Rewards Points: 7,270
Your existing capacitor, is a RUN capacitor.
It does a different job then a START capacitor.
A start cap is more then just another cap in parallel, there needs to be a device to drop it out of the circuit. Or the start winding would burn up.
Many hard start kits come with a device built into the cap assembly.
If you just increase the size of your RUN cap, you can do severe damage to the compressor.
PS: your current one, is a duel run capacitor.
Old 01-06-2009, 08:48 PM   #3
biggles's Avatar
hard start kits boost the windings to get it to start.if your tripping the CB for the condenser an adjustable time delay in series with the 24V R out to the condenser.this will allow the pressures to equalize for an easy start and a crankcase heater will keep the refrigerant liquid from migrating back to the sump.the combo of liquid refrig in the oil sump,and unequalize freon pressure will trip the breaker......adding a hard start will push the winding to overcome these,and add years to that compressor winding.the result is a burn out,and acid thru out the system big bucks to clean up and repair.....and cut back on it operating at its peek during those summer months. check out www.grainger.com item # 4E234 TD item# 4MC05/4MC02 CCH
Old 01-06-2009, 09:00 PM   #4
An old Tradesmen
Thats a HP in that pic.
The defrost board has a time delay built into it.
A proper hard start kit, will not harm a compressor.
Old 01-06-2009, 09:43 PM   #5
Rewards Points: 502
So you are saying that a hard-start kit just adds one in the start position, which I understand...but then why do all the websites that sell them just say it is as simple as hooking two wires up?
http://bestbuyheatingandaircondition...ategory_Code=C
-Andrew
DIY hobbiest
Old 01-06-2009, 11:27 PM   #6
That's where an HVAC education comes in.
hvaclover is offline   Reply With Quote
Old 01-07-2009, 04:47 AM   #7
An old Tradesmen
Because, a single piece kit.
Has lock out device built into it, in series, so it only needs 2 wires.
The trick is, to get one that uses a potential relay, and not a PTC, plus one that is the proper size.
Improper sizing will harm the compressor.
Kits that use a PTC, can damage a compressor. Because they can stay energized too long, or drop out to soon.
And that is why many people still say hard start kits are bad for compressors. They are only use to seeing or using the cheap ones with PTC relays.
In refrigeration, a start kit is common(and often from the factory), and 20 years on a compressor that has one is not unusual.
Old 01-07-2009, 09:38 AM   #8
Remember when Bryant used one on their builders model. That was the old green finned aluminum condenser.
Old 01-07-2009, 09:59 AM   #9
Rewards Points: 502
Ok, I understand now, thank you.
-Andrew
DIY hobbiest
Old 01-07-2009, 04:01 PM   #10
An old Tradesmen
Yea.
And Carrier used starts kits on all their R500 units, as I recall.
Old 01-07-2009, 07:14 PM   #11
I am referring to solid state hard starts
Wkatta piece of **** those Bryants were
Old 01-07-2009, 07:32 PM   #12
An old Tradesmen
Yea, sorry.
I was just pointing out, that Carrier used real good "Start kits" on some of their equipment.
Old 01-08-2009, 11:02 PM   #13
Rewards Points: 502
So I was at the local supply house today, they had two hard start offerings. I opened them up and looked at the directions and BOTH of them said to hook the two wires from this device (capacitor) to your existing RUN capacitor.
So we are all talking about TWO separate things here right? All that would do is boost the run capacitor capacity.
I did pull out the wiring schematic for my HP and see there is an option to wire in a relay and a start capacitor. I will pursue that option as I want to extend the life of my HP.
-Andrew
DIY hobbiest
Old 01-09-2009, 01:39 AM   #14
although its called a run cap its actually wired to the start winding adding the unit you saw at the supply house based on the tonnage is all you need they have been on the market for years and are pretty reliable
kennzz05 is offline   Reply With Quote
Old 01-09-2009, 11:13 AM   #15
Rewards Points: 502
Found the schematics for my HP. Now I know how to wire mine up.
-Andrew
DIY hobbiest
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 07:28 AM
HVAC plans for remodel wease HVAC 3 03-23-2011 10:47 AM
Brand new PAYNE PG9MAB won't start . Error code 12 tp618 HVAC 3 12-19-2008 09:21 PM
Buying a Hard Start Capacitor Help D1G1T4L3CH0 HVAC 3 10-17-2008 08:42 PM
Blue smoke at start up, and shudder at idle fauer Automotive Repairs 6 08-22-2008 11:39 AM
