HVAC In Garage Attic - HVAC - DIY Chatroom Home Improvement Forum
Old 12-12-2010, 10:50 AM   #1
HVAC in Garage Attic
last year drain line froze and sprung a leak. i repaired the leak
current solution is to not use it when it freezes.
not ideal.
had 3 different contractors give feedback
1. told me to tie drain line into sewer using the logic that "it doesn't freeze under house"
2. other told me tie into sewer is dangerous and recommended a heat wrap and shorten drian line and run it right out the top at the eaves.
3. other told me to build a box around it and heat from furnace inside box would keep line warm enough
all said it should have never been installed in the attic because attics always freeze.
so question is
what is the best solution
and where should it have been installed if not in the attic?
bobmane is offline   Reply With Quote
Old 12-12-2010, 10:58 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,238
#2 sounds best. There is not enough water draining and it is not hot enough to keep from freezing. If not in the attic where you have space and ductwork to put it? May have to go there out of necessity.
If you drain it out the eaves make sure it does not stain the wall or create ice where it lands which someone can slip and fall on and sue you.
Old 12-12-2010, 11:59 AM   #3
not ideal.
so question is
I live in VA we install 90% furnaces in attics all the time. The drain line should be on a interior wall and the drains lines in the attic should be insulated. We follow these guide lines and have no frozen lines make sure you have enough fall. You can also use heat tape were it penetrates your wall. Make sure if you use heat tape it is rated for the type of material your drain line is. If unable to run drain lines in interior wall the whole line needs to be insullated .
Hixheat1 is offline   Reply With Quote
Raccoons in the attic electricpete Pest Control 17 05-12-2011 04:02 AM
Insulating the garage attic. CZ4diy Building & Construction 3 11-10-2010 10:05 PM
Insulation in Garage Attic ? SaDan Building & Construction 2 05-09-2010 05:44 AM
Insulating garage / adding attic Red Squirrel Building & Construction 4 04-19-2010 07:33 PM
Garage Attic Floor Joists zacmac Carpentry 3 11-02-2009 09:07 PM
