HVAC Fuse Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 05-31-2010, 09:57 PM   #1
HVAC fuse problem
hello. please help me. my Weather Maker 8000 needs a fuse. i haven't been successful locating the correct fuse. we put in a 30 volts. would that have something to do with the air not blowing strong
linnage is offline   Reply With Quote
Old 06-01-2010, 06:10 AM   #2
biggles's Avatar
are you inside or outside when replacing the fuse.if it is outside the condenser disconnected should be 30 amps typical..change both with new ones HD Lowes hardeware store true valve ACE stores..if it blows again the compressor or its contactor might be a problem...remove the condenser panel and do a visual on the contactor for burnt wires or black arck on the contacts
Blown 5 amp fuse on Carrier System chalkstar HVAC 9 07-22-2014 11:18 PM
My first post! HVAC problem... Deano2450 HVAC 8 10-31-2009 11:56 AM
Electrical "arcing" problem? morden5b Electrical 17 12-17-2008 06:10 PM
100 Amp Fuse - issue - HELP! Leenders Electrical 9 06-02-2008 04:06 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
