Old 07-09-2012, 10:45 PM   #1
HVAC Furnace question
My Furnace is 75,000 BTUs. What would happen if I had a furnace installed that is 115,000 BTUs?
hardentheo is offline   Reply With Quote
Old 07-09-2012, 10:50 PM   #2
An old Tradesmen
Most likely it wouldn't heat your house very well. As it would lock out on its high limit temp because it requires a lot more air flow then your 75,000 BTU. And your duct work wasn't sized for a 115.000 BTU furnace.
Old 07-09-2012, 11:06 PM   #3
nothing good would happen......
carmon is offline   Reply With Quote
Old 07-10-2012, 06:25 AM   #4
Why do you think you need 50% more heating in the home? Are you having trouble heating the home?
scottmcd9999 is offline   Reply With Quote
rerouting HVAC ducting for an upflow furnace joregon3597 HVAC 2 05-03-2012 08:08 PM
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 09:31 AM
Basement Remodel - HVAC Code Question buckybadger HVAC 2 08-16-2011 06:34 PM
Make up ventilation through return on furnace question creamaster HVAC 8 09-27-2009 05:53 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
