HVAC Fresh Air Ventilation - HVAC - DIY Chatroom Home Improvement Forum
Old 10-10-2008, 10:29 PM   #1
Question
I was told by an HVAC contractor that I needed an 8" hole drilled in my foundation so that I could install and 8" duct to bring fresh air into my basement furnace room in order to meet code. 8" seems large for this. I just went to the home improvement store to purchase a vent for the hole to be drilled on Monday and the only thing I could find was 4" vents intended for a clothes drier. It seems like if an 8" outside vent was required for my furnance to meet code, they would be readily available.
SLCDIY is offline   Reply With Quote
Old 10-10-2008, 10:57 PM   #2
oops, did I do that!
Look into "Skuttle Kits". Is your furnace and water heater in an enclosed mechanical room?
8 Ball is offline   Reply With Quote
Old 10-10-2008, 11:04 PM   #3
Where do you live?
Ask the contractor why you need an outside vent.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 10-11-2008, 01:27 AM   #4
That hole is large enough for a 300kbtu furnace. How big is your house?
hvaclover is offline   Reply With Quote
Old 10-11-2008, 08:08 PM   #5
I have an 8" that goes into the end of our return air.
I also have a 6" combustion air. Pipe next to the furnace.
Chimney is 7".
Yea... I got problems...
Things are not balanced in our 1945 home.
At some point I'll get a high-e furnace, electric hw, HRV and then redo the duct work.
unixb0y is offline   Reply With Quote
Old 10-11-2008, 08:22 PM   #6
How 'bout answering some of the qustions so we can try and help out instead of just complaing about it?
Old 10-11-2008, 11:00 PM   #7
tk03's Avatar
Rewards Points: 150
You only need to bring in the amount you are short.
This may be of some help.
http://www.comfort-calc.net/Combusti...lculation.html
tk03 is offline   Reply With Quote
Do I need a HVAC return vent in basement? westing HVAC 13 04-03-2014 02:43 AM
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 08:28 AM
HVAC plans for remodel wease HVAC 3 03-23-2011 11:47 AM
Fresh air home ventilation Jeekinz HVAC 7 04-18-2007 04:08 PM
