HVAC Fan Not Working In AUTO - HVAC - DIY Chatroom Home Improvement Forum
Old 10-31-2010, 08:17 AM   #1
Rewards Points: 342
Question
HVAC fan not working in AUTO
I was getting the furnace ready for winter and while testing the fan I engaged the fan control at the unit itself, pushing it in for manual operation, then pulling back out for auto. Now, back at the thermostat inside the house, the fan only runs in manual, not auto mode. Any ideas?
tripower is offline   Reply With Quote
Old 10-31-2010, 09:12 AM   #2
An old Tradesmen
Rewards Points: 6,928
So when the thermostat calls for heat. The fan won't run?
Old 10-31-2010, 09:14 AM   #3
Rewards Points: 292
When you switch from manual to auto, is there a call for heat indicated on the thermostat?
If not, try goosing the stat up a few degrees.
veesubotee is offline   Reply With Quote
Old 11-01-2010, 03:02 PM   #4
Rewards Points: 342
Exclamation
Did I just not type it correctly, YES, when I turn on the heat and the fan is set to auto the heat turns on BUT NOT THE FAN. I now have to MANUALLY turn on the fan.
Old 11-01-2010, 04:09 PM   #5
An old Tradesmen
What you were talking about was confusing for me at least. If it wasn't. I wouldn't have ask for clarification.
Check that no wires are pinching the dial inside the fan control. if not, then its probably done for. And needs replaced.
Old 11-01-2010, 04:47 PM   #6
Rewards Points: 342
OK, thanks. Any recommendations on replacement controls?
Old 11-01-2010, 05:00 PM   #7
An old Tradesmen
Same brand and model as you have. make sure it is the same insert length.
Old 11-01-2010, 05:44 PM   #8
Rewards Points: 342
Question
Insert length?
Old 11-01-2010, 05:50 PM   #9
An old Tradesmen
The temp probe that senses the heat from the heat exchanger.
When you remove yours, you can measure it.
Old 11-01-2010, 07:15 PM   #10
Rewards Points: 342
Question
can I purchase these at Lowes or HD or at a HVAC shop?
Old 11-01-2010, 07:19 PM   #11
Confusing!! don't come across too many fan and limit controls with summer switch/button these days.ie; conventional furnace maybe...all day long!nice sevice call!!
hf05 is offline   Reply With Quote
Old 11-01-2010, 07:31 PM   #12
An old Tradesmen
I get all my parts from HVAC supply houses. Have no real idea what Lowes or HD have.
Old 11-02-2010, 03:55 PM   #13
Rewards Points: 342
fixed
Old 11-02-2010, 07:02 PM   #14
An old Tradesmen
So what did you do to fix it.
Blower Motor quit, changed wiring now working? wsjr1 HVAC 20 01-10-2010 06:01 PM
HVAC in out Condo Jzone99 HVAC 10 11-21-2009 04:28 AM
Estimate for Basement HVAC in New Construction jb_nc HVAC 4 07-29-2009 11:48 AM
new HVAC & door bell quit didn'tdoit HVAC 3 04-16-2006 06:30 PM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 01:19 PM
