Hvac FAN BLOWING CONSTANTLY - HVAC - DIY Chatroom Home Improvement Forum
Old 03-01-2012, 07:47 AM   #1
hvac FAN BLOWING CONSTANTLY
I recently had a problem with my electric HVAC system. The blower fan ran constantly, even when system off. I had the TIME DELAY RELAY replaced, and it worked fine for one day, maybe two, and now it is right back to blowing constantly. Could something have blown out the new relay, or did I replace the wrong part?
Amorita is offline   Reply With Quote
Old 03-01-2012, 10:54 AM   #2
An old Tradesmen
Rewards Points: 6,140
Could be wrong part. or something else was wrong. need a meter to check.
Old 03-01-2012, 11:12 AM   #3
how
Rewards Points: 1,070
Also check...
Thermostat setting or fault, bare insulation anywhere between thermostat wires R & G , drywall nail doing the same. Try removing thermostat wire from board connection "G" to see if the fan stops.
Lightly tap the fan relay when it should be off to see if it unsticks. Will still need replacing if it does.
how is offline   Reply With Quote
The Following User Says Thank You to how For This Useful Post:
ben's plumbing (03-02-2012)
Old 03-01-2012, 08:49 PM   #4
Rewards Points: 582
well I guess this won't work..ha ha
Old 03-02-2012, 06:01 AM   #5
jkv
He ask for a meter well there you have it amps and volts
jkv is offline   Reply With Quote
Old 03-02-2012, 07:40 AM   #6
Rewards Points: 582
when a limit or another safty switch is open fan runs all the time ..may need to check these things....filters clean?
Old 03-02-2012, 09:32 AM   #7
Hey, don't knock it...Uncle gave me one exactly like that...I hear it's been in the family since the 1920s. Makes a graet conversion piece ...and it sill works.
I collect old HVAC tools....I love the industry history.
hvac5646 is offline   Reply With Quote
Old 03-02-2012, 10:56 PM   #8
Rewards Points: 582
yes agree I have another one even older from indian head
HVAC blowing cold air at nite and hot air in daytime sgtrahlf HVAC 17 08-06-2011 11:24 AM
York HVAC Not blowing air through vents ktellbuescher HVAC 1 07-05-2011 11:51 AM
Runaround - HVAC and HWH proper venting/exhaust denemante HVAC 24 04-05-2011 09:50 PM
moving HVAC system - can I go without gas for a few days? denemante HVAC 2 03-30-2011 05:55 AM
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 08:28 AM
