HVAC Fan - HVAC - DIY Chatroom Home Improvement Forum
Old 12-02-2012, 11:21 AM   #1
Rewards Points: 258
HVAC fan
why do i hear more noise out of my blower motor when in heat mode then i do in cool, its an all in one gas heat unit mounted on the roof. I hear the noise from the air return line not the out put vents
redman88 is offline   Reply With Quote
Old 12-02-2012, 10:43 PM   #2
Rewards Points: 258
No help out there?
Old 12-03-2012, 04:05 AM   #3
An old Tradesmen
Rewards Points: 7,816
Does it use a different speed for heat then it does for cooling.
Old 12-03-2012, 08:56 AM   #4
Rewards Points: 258
not sure, but it does feel like it is slower on heat
Old 12-03-2012, 09:02 AM   #5
An old Tradesmen
May be the mechanical noise of the blower running at a lower speed. Some blower motors labor more at a lower speed then they do at a higher speed.
Old 12-03-2012, 09:07 AM   #6
Rewards Points: 258
whats the best option for fixing it?
Old 12-03-2012, 09:12 AM   #7
An old Tradesmen
Remove the lower speed tap wire from the heating speed tap on teh board, and run a jumper from the cooling board tap to the heating board tap.
I would also check bearing play in the motor.
Old 12-03-2012, 09:35 AM   #8
Rewards Points: 258
no worries about over powering the burners?
Old 12-03-2012, 09:39 AM   #9
An old Tradesmen
The burners don't use the same air as the house does. the burners would be using a draft inducer, which is not the same as teh blower that moves air in your house.
Old 12-03-2012, 02:41 PM   #10
Rewards Points: 258
so is it bad for the motor to be run the way it currently is or should i bypass the low speed?
Old 12-03-2012, 03:47 PM   #11
An old Tradesmen
Shouldn't hurt it.
Thinking about installing my own retrofit AC system-with some help from real HVAC guy BT5150 HVAC 2 08-02-2012 06:43 PM
Runaround - HVAC and HWH proper venting/exhaust denemante HVAC 24 04-05-2011 08:50 PM
moving HVAC system - can I go without gas for a few days? denemante HVAC 2 03-30-2011 04:55 AM
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 07:28 AM
Engineered Joists & holes for HVAC ducts walt1122 Building & Construction 3 07-04-2009 07:37 PM
