-   -   HVAC fan (http://www.diychatroom.com/f17/hvac-fan-165370/)
redman88 12-02-2012 12:21 PM
HVAC fan
why do i hear more noise out of my blower motor when in heat mode then i do in cool, its an all in one gas heat unit mounted on the roof. I hear the noise from the air return line not the out put vents
redman88 12-02-2012 11:43 PM
No help out there?
beenthere 12-03-2012 05:05 AM
Does it use a different speed for heat then it does for cooling.
redman88 12-03-2012 09:56 AM
not sure, but it does feel like it is slower on heat
beenthere 12-03-2012 10:02 AM
May be the mechanical noise of the blower running at a lower speed. Some blower motors labor more at a lower speed then they do at a higher speed.
redman88 12-03-2012 10:07 AM
whats the best option for fixing it?
beenthere 12-03-2012 10:12 AM
Remove the lower speed tap wire from the heating speed tap on teh board, and run a jumper from the cooling board tap to the heating board tap.
I would also check bearing play in the motor.
redman88 12-03-2012 10:35 AM
no worries about over powering the burners?
beenthere 12-03-2012 10:39 AM
The burners don't use the same air as the house does. the burners would be using a draft inducer, which is not the same as teh blower that moves air in your house.
redman88 12-03-2012 03:41 PM
so is it bad for the motor to be run the way it currently is or should i bypass the low speed?
beenthere 12-03-2012 04:47 PM
Shouldn't hurt it.
