Old 07-30-2011, 01:35 PM   #1
Jamntx's Avatar
Hvac fan
I just moved into a home built 2003 in Texas try to turn on ac everything started up but the fan on the outside was not moving what is the cause, it's an amana brand that's all I know. The house is two stories 2400 sq ft
Jamntx is offline   Reply With Quote
Old 08-06-2011, 02:16 PM   #2
Hvac fan
Looks like noone responded. Did you figure it out. I know on our house they put obviously a breaker in the panel but they also put a seperate power switch by the unit itself so we can kill the power there if needed instead of running back and forth to the breaker. I'd start with the breaker, and maybe get a volt meter to verify you are getting power at the unit. Fan motot could be dead as well. Good luck
Kriggio824 is offline   Reply With Quote
Old 08-06-2011, 02:35 PM   #3
Jamntx's Avatar
Hvac fan
Thanks , I called a friend he does Hvac told me it's the capacitor a # 80 for a 5 ton w/heat pump just gonna get the part seems like a simple fix
Old 08-06-2011, 05:39 PM   #4
REP
Hvac fan
Before you go running out to get the capcitor,label the wires asm to where they go and then remove the cap and take it with you to be sure you get the right replacement.You must get the exact microfarad rating.You can go from 370 volt to 440 volt but not the other way around.
The wrong cap may allow the motor to run but it will slowly eat away at the motor windings.
REP is offline   Reply With Quote
Old 08-06-2011, 05:40 PM   #5
An old Tradesmen
Hvac fan
Look at the old capacitor to make sure what one you need. Yours is a dual run capacitor.
Old 08-06-2011, 06:15 PM   #6
Jamntx's Avatar
Hvac fan
Hey thanks guys, really good advice.. As I called grainger and they began asking me specks I will prolly take a pic and bring the cap with me . Btw seems like all the Hvac places close on the weekends, as hot as it is in Texas now, thought theyd be open all week, just my wish, it's the heat talking
Runaround - HVAC and HWH proper venting/exhaust denemante HVAC 24 04-05-2011 09:50 PM
Ductless Mini Split Install - need HVAC Tech! mike_30319 HVAC 13 03-30-2011 07:18 AM
moving HVAC system - can I go without gas for a few days? denemante HVAC 2 03-30-2011 05:55 AM
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 08:28 AM
Engineered Joists & holes for HVAC ducts walt1122 Building & Construction 3 07-04-2009 08:37 PM
