Old 09-04-2007, 03:39 PM   #1
Default HVAC energy saver
Put this under general... maybe best here.
New to form but thought it was an interesting place to mention a new product I have stumbled upon. Houseneeds.com is caring a product called Activent which is a wirelessly controled air register.
Appears Activent also has a website but they direct people to Houseneeds.com Anyone heard of this or used it? Looks interesting.
Robert
Sappronie is offline   Reply With Quote
Old 09-04-2007, 06:04 PM   #2
retired
Robert
Similar type registers were installed in the offices in the building where I used to work. Worked OK as I recall. I would say they would be useful only if you have an issue of a constantly changing temperature in some room. If you have a room that say, during the cooling season is always cold in the morning and hot in the afternoon, then the Activent may work for you. But you need to have capacity in the a/c system to supply more or less air to a given room as needed. In the building where I worked the variable air vents were installed the same time a variable speed drive was added to the air handler. The Activent needs to be a part of a total system design, not just an add-on. Otherwise save the $ and adjust the registers manually.
dmaceld is offline   Reply With Quote
Old 09-05-2007, 11:51 AM   #3
Not sure I understand the variable temperature swing you mention... I think the Activent is designed to control over heated or over cooled rooms. Probably not practical to think someone could manually keep changing the register when this could do it for you.
I think it looks like it is worth the money for those type of problem rooms.
Old 09-05-2007, 02:52 PM   #4
retired
In the rented house we live in the bedroom I use for my office area is on the west side. In the morning and early afternoon after the a/c has kicked on for the day it is comfortable and close to the same temperature as the rest of the house. Toward evening with the sun shining through the window and the computer running all day it gets fairly warm. In this case the Activent might work by clamping down on air flow in the morning and opening up wide in the evening. If a room is always over or under cooled or heated then there is a basic problem in the system design. By that I mean the air flow isn't balanced correctly because of improper duct size or improper register size. That kind of problem isn't what Activent is aimed at. If your heat/cool system is designed correctly, then at any given time you should be able to balance the air flow and have the desired temperature throughout the house. That air flow balance should not change much as the outside air heats and cools. The heating and cooling load can change throughout the day in an individual room, mostly because of windows. That is the type of variation you would want to control with something like Activent.
Any clearer now?
Old 09-06-2007, 01:34 PM   #5
Yes, clearer.
Problem is in most residential homes, built in bulk, I think balance is not tuned to each individual home. So then the Activent would be a benifit.
I too have the perverbial office that heats up with computer, etc. that could use this kind of help.
More On This Topic
With the high cost of utilities these days, cooling your home with an exhaust fan or a series of exhaust fans makes a lot of sense. However, if you don't pay attention to how you're using your fans, your cooling efforts won't be effective. By using these... Read More »
The thermostat on your wall that controls your HVAC system is the key to your comfort. Knowing how it interfaces with your heating and air conditioning system can help you stay comfortable during long, cold winters and hot, sweltering summers. A key part... Read More »
Your home's heating and air conditioning system (HVAC) is one of the most important elements involved in enjoying your home. Besides providing a comfortable environment, your HVAC also helps to maintain your health by protecting you from extreme... Read More »
Tortoise Cage Heating
Tortoise Cage Heating by Expert Village
Okay, so the next thing we want to talk about is the heating of your aquarium. Heating and lighting are two different things, and heating is very important. Without proper heat, your reptile is not going to be able to digest his food correctly. So, what... Read More »
Storing Wine
Storing Wine by Expert Village
Hi, I’m Farley talking about wine today and wine storage is an issue but is very important and a lot of people don’t want to think about. I am down here in the basement because when you are storing wine especially if it is something you want... Read More »
Do I need a HVAC return vent in basement? westing HVAC 12 01-28-2009 02:09 PM
HVAC plans for remodel wease HVAC 2 02-01-2007 11:28 AM
Energy efficient new home? kcrossley2 Building & Construction 10 01-27-2007 11:04 PM
History of HVAC Industry Brands winkydink HVAC 4 11-11-2006 01:41 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
