Originally Posted by Doc Holliday
In no way shape or form should any duct work under ANY circumstance ever condensate. You have a serious problem which is going to lead to mold throughout your home.
The cool air produced from inside your unit which is traveling through your ducts should be insulated to protect it against ever meeting the warm air surrounding it, why duct work is insulated in the first place.
i dont think i have insulation surrounding my ducts..and i have torn open quite a few walls
Originally Posted by hvac122
If you had the doors open as said it will sweat. Did you have the doors open?
well, not exactly a door but i did have a giant cavity in the wall where i was reframing and installing a window.. and the slider was partially open.
i havent had an issue since this incident
