Old 08-17-2009, 12:18 PM   #1
HVAC ducting and foam insulation
I am a homeowner (not a contractor) and installed the ductwork on my remodel job. The ductwork was so tight above the bathroom (finished room above it) that, rather than using the fiberglass batt duct insulation that I used everywhere else, I asked the spray foam contractor to shoot the ductwork in the space above the bathroom with spray foam. The round metal ducts are screwed and sealed with mastic. Now of course the city hvac inspector is telling me this is a code violation and is telling me to scrape all the spray foam off the ductwork and wrap it with fiberglass. I understand that "the code is the code," but is there some drawback to using spray foam insulation on ductwork besides the difficulty I am going to have removing it? Is it approved anywhere??? thanks
seadrift is offline   Reply With Quote
Old 08-17-2009, 01:11 PM   #2
Hvac Pro
I would think it is not rated for a high enough temperature. I have seen furnaces malfunction because of a faulty or miswired limit control and get hot enough to melt the A/C coil drain pan. Fibreglass is not as sensitive to high temp. Foam may gas off and release harmful vapors also.
More On This Topic
Room additions are an exciting remodeling project. It's nice to anticipate the enjoyment of extra space in your home. But you want the room to be comfortable year round for maximum enjoyment. There are several ways and means to accomplish this. Read More »
This is an easy project that not only benefits the environment, but saves you money on your power bills. Having your water heater properly insulated results is less heat loss. So all the energy is spent on heating the water you will use, not wasted in... Read More »
When preparing for the coming winter months, we often think of our precious flower gardens, pets and our homes, but winterizing your garage can be just as important. Winterizing your garage is simple and easy, can protect valuable equipment and will make... Read More »
Replacing insulation is an easy and money saving way to reduce your home's heating and cooling costs. People with good fiberglass insulation installed will never have to replace the insulation again. The easiest time to replace insulation is during home... Read More »
Hi, this is Jon and in this clip we will be filling our gaps. If we take a look at the inside of our door, we do have some gaps that we need to fill so that we don't get any air coming through there. To fill our gaps we are going to be using a spray... Read More »
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
