Hvac Duct Through Fire Wall - HVAC - DIY Chatroom Home Improvement Forum
Old 07-05-2010, 06:30 PM   #1
hvac duct through fire wall
i'm thinking replacing furnace & duct in garage.
The garage to living space wall needs to be fire rated. The ducts will be running right through that wall. How do you maintain fire seal around the ducts (or anything else that goes through the wall for that matter)?
also the part of the duct thats in the garage needs to be 26 gauge with min R4 insulation. Is that right?
acerunner is offline   Reply With Quote
Old 07-05-2010, 07:00 PM   #2
An old Tradesmen
Rewards Points: 6,570
Fire caulk.
Code will probably call for R6 min insulation, if not R8.
Old 07-05-2010, 07:50 PM   #3
so you spray that in the gap between drywall and duct? Do you ned anything between duct & framing?
also, what if the duct is run along the far upper corner of the garage such that you can only reach 2 of the 4 sides to spray the insulation?
Old 07-05-2010, 07:55 PM   #4
An old Tradesmen
Fire caulk isn't a spray. Its a caulk like you use for sealing a widow.
If you can't get to all the sides. They will probably fail your inspection. And make you redo it.
Best thing for you to do. Is find out from your code department what they want done. Guessing could cost you 1000s.
Old 07-05-2010, 08:25 PM   #5
Rewards Points: 85
For rec duct you can screw 1/8" angle around it and mud over with F/C.
Being you are in Cali. you might need a fire damper with break away joints.
Here in Ga. we can hook duct board to a F/D.
And I don't think R4 will fly in Cali.
mikethe ductman is offline   Reply With Quote
Old 07-05-2010, 08:49 PM   #6
sorry. for some reason i was thinking about spray insulation.
I haven't installed anything yet. I am just trying to think of all options or issues. I'm trying to find a new location for the furnace, and that corner of the garage is one of the suggestions from the pros.
Old 07-05-2010, 08:51 PM   #7
r u talking about something like this?
Old 07-05-2010, 09:04 PM   #8
Rewards Points: 85
you might need that in Cali.
You know how those liberals are, always worrying about peoples safty.
Old 07-05-2010, 09:35 PM   #9
Hvac Pro
yuri's Avatar
Rewards Points: 1,452
I would check with your local building codes dept. Another poster mentioned that they may even have rules for furnaces etc because of movement from a possible earthquake.
Old 07-06-2010, 01:36 PM   #10
I realize this isn't going to solve the OP's question but doesn't "Great Stuff" make a red colored spray foam used for fire block?
Mike in Arkansas is offline   Reply With Quote
Old 07-06-2010, 05:09 PM   #11
An old Tradesmen
I don't know.
Old 07-06-2010, 06:56 PM   #12
u mean this stuff?
http://building.dow.com/na/en/produc.../fireblock.htm
Old 07-06-2010, 09:44 PM   #13
Originally Posted by acerunner View Post
Yes that's it. Seems like I saw on Ask This Old House that its the same as the regular foam except its colored red.
Running speaker wire from attic into exterior wall: Techniques? homerb Home Theater 1 07-15-2010 02:55 PM
How to frame door under hvac duct cai Building & Construction 5 06-15-2010 08:05 PM
HVAC duct work radiates 60Hz Mike in Arkansas Electrical 3 01-01-2010 08:29 PM
Framing wall under duct JiD Building & Construction 1 03-31-2008 01:10 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
