HVAC Duct Size For Toe Kick Installation - HVAC - DIY Chatroom Home Improvement Forum
Old 02-18-2012, 05:32 PM   #1
HVAC duct size for toe kick installation
Hi all,
I have a heating duct which came up in the middle of the kitchen floor, and with my remodel, I am moving it to the outside wall to come up under a kitchen cabinet and out through the toe kick.
There is a ~10' run from the main feed to where it would come up from under the cabinet. The cabinet seems to have a 4" toe kick, which I believe means that I should use a 4" duct to feed the vent. The current duct coming off the main run is 5". What is the best / proper way to run the feed? I have to reduce to 4" (or 3"???), so I'm wondering where to reduce at, if it really matters... (beginning of run, right before the bend up through the kitchen floor, etc...)
Thanks,
Joe
joeh is offline   Reply With Quote
Old 02-18-2012, 06:04 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Use the 5" for the feed. Make it come up under the cabinet and then install a 2"x12" register in the toe kick
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
The Following User Says Thank You to Plumber101 For This Useful Post:
joeh (02-18-2012)
Old 02-18-2012, 06:09 PM   #3
REP
The smallest that run should be is 5" but if it were me I'd change it to a 6" run to a 2 1/4x 12" stack to toe kick grille.
REP is offline   Reply With Quote
The Following User Says Thank You to REP For This Useful Post:
joeh (02-18-2012)
Old 02-18-2012, 06:22 PM   #4
If you have space u could go to rectangular duct to your boot connection.
hvac5646 is offline   Reply With Quote
Old 02-18-2012, 06:28 PM   #5
Perfect, I think that means I'll just dump the duct feed into the cabinet void and use that as my final run. Then use the 2 / 2.5x12 grille. Maybe make a plywood box so the entire 20x24 cabinet base is narrowed down for airflow. I was worried about dropping to 4" flex, so that helps.
Thanks to both of you.
Old 02-18-2012, 07:53 PM   #6
An old Tradesmen
Rewards Points: 6,116
make sure your entire outside wall is sealed well.
Old 02-18-2012, 09:45 PM   #7
REP
Why do a lazy azz job? stack is cheap.Run the stack from the transition boot to the toe kick.Then put the grille on the outside of the toe kick.That way you will get way more heated air into the kitchen and not waste it warming up the bottom of a cabinet.
You know in most cases it only takes a little bit to do trhings right.
The Following 2 Users Say Thank You to REP For This Useful Post:
ben's plumbing (02-18-2012), joeh (02-18-2012)
Old 02-18-2012, 10:44 PM   #8
It wasn't that I wanted to do a lazy job, it was confusion on what was being said, and my situation. I would probably spend more time on that plywood enclosure than what you're describing!
I've done a few searches, and I think I understand a bit better. 5" feed duct (or 6" as you earlier recommended, but the transition from the main duct is already 5", and replacing that with a 6" seems a bit trickier), then to a 90 degree bend through the floor. Connect that to an elbow boot to transition from 5" round to 2 1/4 x 12, and then run the 2 1/4 x 12 stack to the toe kick.
Goofy me, I didn't realize there were 2 1/4 x 12 stack runs, as I thought I would have had to do the 5" round (which wouldn't fit under the cabinet) and then use a boot to the toe kick. It'll be a bit tricky due to joists and all for centering it and getting the proper length, but I understand what you're saying. Thanks for clarification, as the possibilities make MUCH more sense now. I'll see what pieces are at my local store.
Old 02-18-2012, 11:00 PM   #9
Rewards Points: 582
yes agree with rep on this one... install stack pipe under vanity ...don't use bottom of cabinet .....
toilet/sewer pipe size venting cdhoustonusmc Plumbing 3 12-11-2011 11:19 AM
Pipe Size guymwf Plumbing 0 11-09-2011 01:37 PM
Sewage grinder pit and pump installation leff1rj Plumbing 15 02-04-2011 12:36 PM
size of drain pipe eice Plumbing 4 09-19-2010 09:03 PM
First Furnace Install - Need Some Help Getting Started hartkem HVAC 17 10-11-2008 12:55 PM
