HVAC Cooling Issue. - HVAC - DIY Chatroom Home Improvement Forum
Old 05-24-2012, 09:03 PM   #1
Missouri Bound's Avatar
HVAC cooling issue.
Turned my AC on for the first time this year. Started to cool, but slowly. Temp in the house was 77 to start, and went to 74 in about 3 hours....then it went to 75. The temperature at the registers was right at 60 deg. The air flow seemed diminished at this time so I turned off the unit and opened the filter compartment....the filter was perfectly clean as I changed it right at the end of the heating season. Opened up the blower compartment and noticed that the A coil was frozen over. Opened the blower compartment and turned the unit back on, and the blower was operating normally at proper speed. The unit is now 10 years old and it is a heat pump with electric resistance emg. heat.(second stage).
So, my first thought was restricted air flow, but that doesn't seem to be the case. The outdoor unit seems to be fine, but can't verify the outdoor fan speed as of yet. Not sure of the charge either.
Where do I begin to trouble shoot?
Do you want it your way or the right way?
Old 05-24-2012, 09:49 PM   #2
Typical low freon problem. There is a leak somewhere. find and fix the leak, then recharge the system.
clocert is offline   Reply With Quote
Coleman DGAA mobile home furnace issue baluna HVAC 9 04-07-2012 09:55 AM
HELP!!! How much owe my HVAC repairman? Is he competant? MB1 HVAC 23 02-01-2012 03:42 PM
Moving HVAC system dilemma denemante HVAC 4 03-18-2011 05:55 PM
General HVAC Design Issue Robert Green HVAC 4 05-29-2010 12:02 PM
Master/Slave Central HVAC? teoteodore HVAC 0 12-09-2009 06:19 AM
