HVAC Condensor Won't Shut Off - HVAC - DIY Chatroom Home Improvement Forum
Old 07-06-2013, 02:35 PM   #1
HVAC condensor won't shut off
My problem is different as I removed the tstat from wall to paint and repair texture and when reistalled the condensor runs constantly. If I turn the tstat off, the condensor still runs. I have to think it's something I did while removing and reinstalling the tstat to the wall, but I made a diagram of wire locations on the electromechanical tstat before removal and have checked it several times since. Does this sound like the 4 wire lead has a short or break in it? The only way to stop the condensor is by throwing the on/off power supply switch on the wall next to the air handler.
jimtone is offline   Reply With Quote
Old 07-06-2013, 02:40 PM   #2
Old 07-06-2013, 02:43 PM   #3
PoleCat's Avatar
Rewards Points: 1,646
When this happened to me I found an earwig crunched in the contactor. It effectively held it closed.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 07-06-2013, 02:53 PM   #4
On the contactor is the tstat? I'm not thinking this is my trouble since I drug a clean dollor bill thru the contacts yesterday.
Old 07-06-2013, 03:02 PM   #5
PoleCat's Avatar
The contactor is in the outside unit. Inside you may have smashed the wires when you reinstalled the stat and made a short.
Old 07-06-2013, 04:19 PM   #6
Experienced HVAC Tech
HVAC1000's Avatar
Sounds Like a short or its wired wrong. Try just posting this in one thread
HVAC1000 is offline   Reply With Quote
Old 07-06-2013, 04:45 PM   #7
An old Tradesmen
Rewards Points: 6,116
Or, you may not have it wired right. What wire is connected where on the thermostat.
Old 07-06-2013, 04:52 PM   #8
An old Tradesmen
Merged this topic to one thread.
Old 07-06-2013, 05:23 PM   #9
biggles's Avatar
so you removed the wires and wrote the colors to lettered terminals down? subbase and all RED /R.... Green/G... YELLOW/Y...WHITE/W and of course you shut the furnace off right.... so you didn't short wires
Old 07-06-2013, 09:58 PM   #10
HVAC1000's Avatar
Did u do anything with the wires at the air handler?
thermal equalizer on hvac control question Guam HVAC 4 12-07-2015 04:09 AM
Runaround - HVAC and HWH proper venting/exhaust denemante HVAC 24 04-05-2011 09:50 PM
Shut Off Valve won't shut off DIY_Dumbie Plumbing 1 07-11-2009 03:22 PM
Community water shut off zevon Plumbing 14 10-03-2008 08:16 AM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
