HVAC Condensor - HVAC - DIY Chatroom Home Improvement Forum
Old 09-01-2008, 09:26 AM   #1
hVAC Condensor
I am about to purchase a condo and had a Home Inspection done a couple of days ago. The inspector stated that the condensor was on top of the roof and could not inpsect it. The Unit itself is inside he said it was a central 1 zone, forced air split system. The condominium unit was built in 1983, he said the system was old. What do I do to see how much longer it might last. He said it would cost $1000's to intall a new one.
pwheeler is offline   Reply With Quote
Old 09-01-2008, 02:45 PM   #2
coolmen's Avatar
typically you would get a hvac company to come out to inspect system for you to be sure of a good working system.
coolmen is offline   Reply With Quote
Old 09-03-2008, 12:05 AM   #3
Electrician
SD515's Avatar
Rewards Points: 504
Don't be shocked if it's a little more than a $1000 to replace if the condensor's on the roof.
Do I need a HVAC return vent in basement? westing HVAC 13 04-03-2014 02:43 AM
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 08:28 AM
HVAC plans for remodel wease HVAC 3 03-23-2011 11:47 AM
Condensor drain Captflx HVAC 6 08-17-2008 11:19 AM
