HVAC Cold Air Return Question - HVAC - DIY Chatroom Home Improvement Forum
Old 01-22-2012, 03:45 PM   #1
HVAC cold air return question
My wife and I have a small daughter that is almost to the crawling stage and in our home we have one of those big floor intakes that measures 28x36x19. What I want to do is move it to the wall directly above where it is now so that we don't have to worry about her little toes getting stuck in the grate and frankly we're tired of having to step over it. Its located right at the hall entrance and theres just enough space to step around it when our gas fireplace is off, when its on you really have to be careful how you step around it. I also hoped to be able to put the filter up here in the house instead of having to get under the house every time it needs changed. Our house is 1134 sq ft and we think its a 1 or 1.5 ton unit. Thanks.
cmccarter is offline   Reply With Quote
Old 01-22-2012, 03:57 PM   #2
how
Rewards Points: 1,070
The potential problem with just moving it over to the wall is maintaining the same volume of the return air when it gets reduced to using the wall as part of the ducting. It can be done but takes some creative thought and a much wider duct to make up for the depth restriction in the wall over what you probably had in the floor. What is the narrowist dimension of the return ducting system that attaches to that grill. Is it the only return air grill in the house?
how is offline   Reply With Quote
Old 01-22-2012, 04:06 PM   #3
Yes, it is the only one, and size is not really an issue because behind the wall is our bedroom and there is 14 in. of space between the wall and the door frame. My idea had been to put the intake box there as I have a space 14 in. deep and 55 in. from the corner to the closet. Our closet is outset into the bedroom so I have an unused nook there. I had thought if I put the intake there and build a plywood box to house it then I could build some shelving aroung it and use that area for storage. My main question is what dimensions the box should be and what the minimum size of the intake grate in the wall would need to be.
Old 01-22-2012, 04:43 PM   #4
REP
Before you do anything,eliminate the "I think" and the wild "guess"
There is a proper way to do it that will give you exact numbers to work with.
You must have a proper manuel "J" and a manuel "D" done.These are engineering calculations that will give exactly what size equipment and exactly what size duct work your particuliar house needs.
REP is offline   Reply With Quote
Old 09-21-2012, 10:36 PM   #5
how
Misplaced posting. Dam that friday evening beer.
Old 09-24-2012, 11:47 PM   #6
how
Ok this is the second time a posting has ended up here that shouldn't.
Can anyone tell me how to delete a posting. I try through the edit button but obviously don't know what I'm doing or what the trick is.
Old 09-25-2012, 12:49 AM   #7
DIY Enthusiast
sublime2's Avatar
Hit edit
Remove all your text and type this: ...........
sublime2 is offline   Reply With Quote
The Following User Says Thank You to sublime2 For This Useful Post:
how (09-25-2012)
Old 09-25-2012, 05:29 AM   #8
An old Tradesmen
Rewards Points: 6,098
Just use the report button, and one of us will delete it for you.
Old 10-11-2012, 01:41 AM   #9
how
Old 10-14-2012, 08:28 PM   #10
how
If you are sure your heat exchanger is good and you wish to keep this furnace going longer, then the sticking gas valve and regulater gets swapped for a regular gas valve. Adaptations are needed for the difference in gas pipe length and the pilot tube end.
I would recommend only getting an HVAC gas fitter to do this.
Old 10-14-2012, 08:52 PM   #11
Rewards Points: 582
lol:laughi ng: hey how i don't know how to remove it either
Old 10-14-2012, 09:16 PM   #12
Rewards Points: 610
didn't you mean damn those Friday evening beers
are those American beers? you should try Canadian beers then you wouldn't even be able to find this forum
techpappy is offline   Reply With Quote
The Following User Says Thank You to techpappy For This Useful Post:
ben's plumbing (10-14-2012)
Old 05-02-2013, 09:15 PM   #13
how
Any Carrier Jocks out there
HVAC maintenance, low CFM in cold air return asimba2 HVAC 10 12-12-2011 07:30 PM
Closing off HVAC return and supply vents Kulingar HVAC 6 11-15-2011 10:22 AM
Cold Air Return Question avtck HVAC 3 01-08-2010 08:47 PM
Basement Cold air return Bcoleman6 HVAC 2 06-07-2008 09:42 AM
HVAC return vent location question fatboy HVAC 1 03-10-2008 09:56 PM
