HVAC Carrier 38chc - HVAC - DIY Chatroom Home Improvement Forum
Old 05-28-2009, 08:54 AM   #1
HVAC Carrier 38chc
AC central unit that is 9 years old, that had to be recharged and seem to be hold it. The tech that had done the work said there must be a leak and the unit should be replaced. Should I have it repaired or replaced? If replaced what brand should I be looking at? I really don't want to replaced the furnace because it's only 9yrs old and have not had a problem with it.
RWaltz is offline   Reply With Quote
Old 05-28-2009, 11:05 AM   #2
An old Tradesmen
Rewards Points: 6,836
Have it leak checked.
Might be an easy repair. Might be an expensive repair.
Old 05-28-2009, 11:18 AM   #3
With a unit in that mid-age it might be worth the money to have them find and fix the leak. Don't know what UTC's warranty was on those units back then, so I would check to be sure you don't have at least a parts warranty still active.
If it is determined you need a new outdoor unit you may be able to just replace that and reuse the indoor coil and possibly the lineset, depending on age, SEER rating, how much you use your A/C. Regardless, there is no reason to replace your furnace.
dac122 is offline   Reply With Quote
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 07:28 AM
HELP! Carrier Weathermaker Infinity Not Working! MaxPierre HVAC 27 01-19-2009 06:30 PM
Carrier rep coming to diagnose a problem Faulknertw HVAC 14 07-16-2008 11:25 PM
1997 carrier hvac with heat pump pdominoexpress HVAC 5 01-17-2008 10:46 PM
