HVAC-Calc Trunk Size - HVAC - DIY Chatroom Home Improvement Forum
Old 11-22-2011, 08:07 PM   #1
I have run HVAC Calc and get it all but duct sizing
so far this site has been a great help
Can anyone help me with this diagram
I understand the branch sizing and the split returns
but the Trunk is got me stuck
see attachment
I forgot to mention all duct is PVC and Under Slab
BSB00 is offline   Reply With Quote
Old 11-23-2011, 08:56 AM   #2
Rewards Points: 154
duct sizing
First may I start with a question of why your going under slab with the duct?
When you say PVC are you talking about PVC coated metal or Sch. 40 PVC pipe.
Im not absolutely sure but I think using PVC pipe is illegal.
Patrick Eubanks is offline   Reply With Quote
Old 11-23-2011, 05:49 PM   #3
An old Tradesmen
Rewards Points: 6,088
Your next to last branch/supply will be your longest supply run. So what is that total length?
Also, the supply you have coming off the end. Don't do it. make it come off the trunk a foot or 2 back from the end, or you have a noise problem there, along with it being hard to control how much air comes out of it.
Old 11-24-2011, 07:16 PM   #4
Total lenght is the lenght of the supply duct plus the next to the last longest branch??
This where I get really confused reading manual D
On the Trunk and reductions
The long side of the supply is 45 feet with a 45 degree bend then 35 feet
the short side is 35 feet straight run all branch planned on 6 inch or 4 inch by cfm shown
PVC is legal as long as it is encased/dirt or concrete
Thanking in advance Brian
Old 11-24-2011, 07:42 PM   #5
An old Tradesmen
You probably have a total equivalent length of 295 foot.
The supplies are sized by the same friction rate that the supply trunk is sized by.
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 08:28 AM
Need help with New HVAC Reducing Plenum Duct Design Matt2010 HVAC 1 11-14-2010 05:48 PM
Furnace & AC size TB3 HVAC 4 11-06-2010 03:11 AM
How to drywall wall with HVAC trunk and pipe penetrations daphilli Drywall & Plaster 3 09-27-2010 03:15 AM
Adding to existing HVAC daveyd HVAC 4 05-15-2009 02:12 PM
