HVAC Blower Not Running - HVAC - DIY Chatroom Home Improvement Forum
Old 05-11-2013, 08:48 PM   #1
HVAC blower not running
My AC came on today, but I noticed nothing was coming out of the vents. I could hear the condenser running outside, and sure enough it was. The condenser fan was working...I'm assuming the compressor was working as well. It had been on for a few minutes, and I noticed the one refrigerant line was frosty. I was looking at the HVAC unit in the basement, and I noticed the blower wasn't running. I turned the AC off, and turned the heat on. The heat kicked on right away, but no blower. I tried just turning the fan to "on" from the thermostat...nothing. I have a forced air system, gas heat, electric AC. So, is the blower motor bad? Is there a relay or other electrical component that blew up? Any quick/easy way to tell?
mreber is offline   Reply With Quote
Old 05-11-2013, 10:30 PM   #2
Rewards Points: 616
yep.... use a meter and see if the motor has power to it.....
carmon is offline   Reply With Quote
Old 05-11-2013, 10:35 PM   #3
Is it 208/230 are 120?
Were do fan wires pug in to. A board are a relay.
spider79 is offline   Reply With Quote
Old 05-11-2013, 11:47 PM   #4
Experienced HVAC Tech
HVAC1000's Avatar
also use your meter to check the MFDs of the capacitor. if it is just the capacior it will save you the costly replacement of the whole motor plus the capacitor
HVAC1000 is offline   Reply With Quote
Old 05-12-2013, 01:55 AM   #5
Rewards Points: 744
um...what?
Seattle2k is offline   Reply With Quote
Old 05-12-2013, 02:08 AM   #6
Do fan wire go to a circuit board are a relay? If u can power the motor direct to see if it comes on. If its 120 then keep common were its at then hook black wire to 120 side of contactor. Power up if motor comes on then its not ur motor. If don't cone on then check capacitor. Let us know what u find.
Blower motor shuts off while condenser is still running redheaddmsu HVAC 1 08-24-2011 03:17 PM
Wiring help on HVAC blower for Air Filtration oxicottin Electrical 0 03-20-2011 02:34 PM
hvac blower vs capacitor, does my conclusion make sense? Lalan64 HVAC 2 07-17-2010 08:24 AM
Trane Furnace Blower Running Nearly Continuously stephensandlin HVAC 3 01-03-2010 01:21 AM
HVAC system heat won't run with standby generator running... PTighe Electrical 70 09-14-2009 05:35 PM
