Hvac Blower Motor Wiring - HVAC - DIY Chatroom Home Improvement Forum
Old 07-07-2011, 12:41 AM   #1
hvac blower motor wiring
Im replacing my blower motor on my furnace and the new motor has a few diffrent color wires then the old one. Ex: there is only one brown wire so what other wire goes to the capacitor? also it has an orange wire but it is connected to te yellow wire. I have a 2 stage furnace so im asuming i need the yellow and orange but i need a little direction.
jason richman is offline   Reply With Quote
Old 07-07-2011, 01:06 AM   #2
JJboy's Avatar
Orange wire connected to yellow wire is rotation.
Brown - capacitor.
You should have Black, White......what else?
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-07-2011, 01:20 AM   #3
brown, red, blue
Old 07-07-2011, 01:30 AM   #4
JJboy's Avatar
Green - Ground to cabinet
Brown -------| Cap |-------------Line
White --------| |
Black - High Speed -------------Cooling
Blue - Med Speed -------------Heat
Red - Low Speed
Old 07-07-2011, 01:35 AM   #5
Do I hook the white wire to th other side of the cap and then to common? can you explain what rotation is and if i need to do anything with the yellow and orange wires?
Old 07-07-2011, 01:58 AM   #6
JJboy's Avatar
You need to check blower rotation.
CCW Yellow - Yellow
Orange - Orange
CW Yellow - Orange
Orange -Yellow
You need to connect brown wire to one side of the capacitor and white wire to another side of the capacitor then where to line is or board control.
Old 07-07-2011, 02:14 AM   #7
I dont know if it matters but do I come off another port on the cap and then to line with the white wire or do I pig tail? Also there was no orange with the old motor so where do I hook the new orange. I cant do orange - orange.
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 05:39 PM
Help with HVAC blower motor wiring Jcpilot Electrical 4 03-18-2012 03:28 PM
Goodman HVAC system blower stuck on? OhNoes HVAC 14 09-03-2011 08:32 PM
hvac blower vs capacitor, does my conclusion make sense? Lalan64 HVAC 2 07-17-2010 09:24 AM
Goodman HVAC gmp100-3 Inside blower problems ray_adrea HVAC 4 06-28-2007 01:31 PM
