Old 08-02-2012, 09:53 PM   #1
HVAC Blower
I have a mobile home and the led on the HVAC blower keeps tripping the light to show reversed polarity. I turn it off it is good for a while and then it happens again. Is this a sign the board is going out? I am sure I could find a replacement for it if it is but I need to know how to diagnose it first.
jb26jb1981 is offline   Reply With Quote
Old 08-02-2012, 09:54 PM   #2
HVAC Blower
check polarity
carmon is offline   Reply With Quote
Old 08-02-2012, 10:14 PM   #3
HVAC Blower
are you sure the code you are seeing is for polarity reversed? If not new furnace and no work has been done lately this would not be a common problem. Once you reset board by turning off and on if polarity was reversed it would remain reversed. Check code again and unless you have a power supply issue I would think the board is acting up.
turnermech is offline   Reply With Quote
Old 08-03-2012, 12:20 AM   #4
HVAC Blower
Need to reverse your line voltage to your furnace. Should fix the problem.
ResidentialTech is offline   Reply With Quote
Old 08-03-2012, 08:16 AM   #5
I'm Your Huckleberry
HVAC Blower
Is this a new issue, has this system been working properly for some time before?
Thanks.
Doc Holliday is offline   Reply With Quote
Bryant Plus 90 - No Blower Ducaticorse HVAC 11 10-16-2012 09:39 PM
Help with HVAC blower motor wiring Jcpilot Electrical 4 03-18-2012 03:28 PM
separate switch for blower in HVAC system lettersoup HVAC 3 11-11-2011 11:13 AM
Goodman HVAC system blower stuck on? OhNoes HVAC 14 09-03-2011 08:32 PM
hvac blower vs capacitor, does my conclusion make sense? Lalan64 HVAC 2 07-17-2010 09:24 AM
