Old 11-14-2011, 06:49 PM   #1
HVAC in basement
I am finishing basement bedrooms and adding bath. 1 built around any of the hvac that is ran to vents but the big cold air return extends all the way across the room. I am wondering if I can shorten it to accomidate closet? and the system that runs across to the vents on other side of the house is a 8X24 sytem that is supplying 3 vents. I want to shorten the cold air return and the supply 8x24 into a 8 x 12 supply?
if I didnt explain it properly sorry, Im new to HVAC.
Shawn
Shawnzy is offline   Reply With Quote
Old 11-14-2011, 07:06 PM   #2
I'm Your Huckleberry
HVAC in basement
Simply shortening a run is not a concern on either end but making the diameter of the run smaller is a serious hazard to your a/c system's health.
Doc Holliday is offline   Reply With Quote
Old 11-14-2011, 07:33 PM   #3
HVAC in basement
Ok so I can shorten the cold air return thanks!.. now the big supply is reduced 6ft into the room into the 8 x 12 line... the big 8x24 has 3 runs off of it and where it is reduced into 8 x 12 it has 4 runs off of it? seems kind of odd?
What kind of area can the cold air return be closed into to still efficient to supply A/C system. I want to build a 6ft long by 3ft deep by 6' high closet and hoping that will be sufficient enough for the cold air return so I can tuck it away in closet? I have seen them many times in closets not very big but I dont want to take a chance so im curious.
Thanks Shawn
Old 11-14-2011, 08:09 PM   #4
HVAC in basement
depends on the size of the system. By closet I'm taking vertical unit on a platform with a big square hole cut out under it to a return air grill (with a filter) on the wall in front of it? Is that right?
Old 11-14-2011, 08:23 PM   #5
HVAC in basement
http://www.comfort-calc.net/cfm_chart.html
your system needs to move a certain total cfm to be efficient. Each size duct allows a certain cfm to the room it supplies, reducing or deducting from the total cfm supplied by said system until it's all used up.
i don't know what your system size is or what your duct work sizing is like sitting from here.
Old 12-05-2011, 08:15 PM   #6
HVAC in basement
The duct size is 18 x 8. I have some pictures now, I want to shorten the cold air return, and run the 18x8 trunk on a couple quick 45's or 22's whatever I can get my hands on and run it along the wall so I only have to make a small 18inch soffit rather then a 40 inch sofit which kills the space in the room.
HVAC in basement-2525.jpg   HVAC in basement-9898.jpg   HVAC in basement-98797.jpg   HVAC in basement-65654.jpg
How to - prevent basement mold crazymountain How To Guides 31 01-20-2012 08:59 PM
DIY relocation of HVAC ducts cbrc5eric HVAC 6 05-26-2011 09:29 PM
Drastically Different Basement HVAC Instal Costs ... Why? sTiZZiT Off Topic 7 11-27-2010 07:35 PM
Need HVAC solution for basement - 3 zone? or ductless units? skylake HVAC 2 10-06-2009 08:42 PM
Basement HVAC lhempel HVAC 1 12-02-2007 09:12 PM
