HVAC - Airflow Issue - HVAC - Page 4 - DIY Chatroom Home Improvement Forum
Old 01-30-2009, 04:37 PM   #46
Rewards Points: 502
Originally Posted by beenthere View Post
Makes a real BIG difference in the return.
I usualy use a$$ checks in the supply if I have to dead head like that.
Its basically a simple v.
You have to position it, for the air flow you need in each duct.
So you need to knw which side needs more air.
I believe you, I am just trying to grasp why it makes such a big difference in the return. I understand the dead head of coming out of the AH...although it is WAY quieter than it used to be. I could just make a V and insert in there too, right?
To increase airflow through the filter rack, should I do a 4" deep filter instead of a V design?
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 01-30-2009, 04:39 PM   #47
Rewards Points: 502
Originally Posted by AndrewF View Post
In summary:
Total Heat Gain: 37,917 BTUH
Total Heat Loss: 61,166 BTUH
Sensible Gain: 34.694.
Referencing back to the load J I did.
Is my problem that my house is losing 61,000 BTU/HR? and at 17 degrees the heat pump can only generate 36,000?
-Andrew
DIY hobbiest
Old 01-30-2009, 06:22 PM   #48
An old Tradesmen
Rewards Points: 6,140
That does require your strip heaters to make up the difference.
And the strip heaters cost a lot more to run, then the heat pump.
The U turn, the air makes at the base, is very restrictive. You don't want an air filter right there. The air is too turbulant.
With your current set up. Air is not moving at the outer areas of the duct.
So your not using the full area of the duct.
Vanes will help the air to be able to use the full area of the duct.
Be carefull, not to make the V too deep, or it can restrict air flow.
Old 01-30-2009, 07:44 PM   #49
Rewards Points: 502
I understand now. As for the location of the air filter, did I pick a good spot to put it in? Near the middle of the return trunk?
I thought about taking a 2"x2" 90 degree piece of sheet metal and putting in the supply duct right about the AH....would that be an ok size?
I figure I can notch a V in the side of the supply trunk and slide it in rather easily.
-Andrew
DIY hobbiest
Old 01-30-2009, 10:11 PM   #50
An old Tradesmen
The V can be 2 to 4" deep depending on how far it must be moved toward one side or the other, for air flow.
And the wide for eaxh sde should be 1.5 times its depth.
You want to put a radius on it, similar to this drawing.
Old 01-30-2009, 10:12 PM   #51
An old Tradesmen
The air filter in the horizontal duct is a good location.
Old 01-30-2009, 11:11 PM   #52
Rewards Points: 502
I am still puzzled why a 4" thick filter is better than a 1 filter in a V design....wouldnt a v design offer my sq in for filtration?
-Andrew
DIY hobbiest
Old 01-31-2009, 06:57 AM   #53
An old Tradesmen
Because of the way the air is forced through the filter.
At the sides.
A 4" media air filter will have several times the surface area of the V coniguration. Much less restrictive.
Old 01-31-2009, 06:39 PM   #54
hi guys sorry to jump on your project here but i have a very similar problem with air flow. on two registers in my house i have a 20 degree differnce in air temp from any other register in the house. both of these ducts are 6inch rounds into the same side of the vertical plenum. they also have the same air flow problem from the rest of the registers in the house. do you think if i installed the 'V' at the top of the plenum it would help the air movement and heat differential to both of the affected registers??? thanks so much for your knowledge.
derryank is offline   Reply With Quote
Old 01-31-2009, 07:13 PM   #55
An old Tradesmen
Not enough info to say for sure.
Is it a heat pump.
Do those supplies run through an unconditioned area.
Are those runs a lot longer then the ther runs.
Old 01-31-2009, 08:04 PM   #56
Thanks for your reply.All runs are through a "comfoftable Basement" 50 degrees or so.
I have taken temps on each run.Each sample was taken 12" from the plenum and at the registers.
The run in question is 25 degrees cooler than the other runs(12"from the plenum and at the registers on the first floor). This is a gas forced hot air furnace.
Thanks in advance.
Old 01-31-2009, 09:38 PM   #57
An old Tradesmen
Changing their take offs to scooped take offs, may help.
Pull your air filter, and then see if they blow out more air. It could be a lack of return air problem.
Tags
v shap filtration
New HVAC Issue calvins HVAC 6 11-14-2011 10:37 PM
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 08:28 AM
New test being conducted! Still hvac issue! MrShadetree0222 HVAC 24 10-21-2008 11:44 PM
HVAC humidifier issue rfjm58 HVAC 4 04-12-2007 07:46 PM
