HVAC Air Duct Boots / Registers Insulation - HVAC - DIY Chatroom Home Improvement Forum
Old 08-23-2012, 02:25 AM   #1
I have a house that was built in 1977 in houston which I bought last year. The AC system up until the boots/Register/vents were installed in 2007 or 08. and the Air Duct boot/Register/Vent ( I am not sure exactly what they're called) has insulation on the inside that has overspray from when they did the ceiling and mold present. I just removed the insulation which to me does not make sense, however I cleaned the area where the over spray occured with bleach and like I said removed the insulation on all of them and cleaned them with bleach. My Question is; Does this insulation that looks dirty and old need to be there? What purpose does it serve? I thought insulation is for the outside not inside your air system especially at the end where condensation might collect along wth mold.
HolyDiver72 is offline   Reply With Quote
Old 08-23-2012, 04:42 AM   #2
An old Tradesmen
Rewards Points: 8,168
The insulation is to help prevent condensation.
Post some pics of the boots.
Old 08-23-2012, 01:19 PM   #3
That's what I assumed, Coming from the NE I have never seen this, so I thought it was strange. It will only allow me to upload 100KB, the file is 1.05 MB. Can I replace this type of insulation or even should I? Do I really need it? Or am I going to have to replace all the boots as well.
Thanks for your answers.
Old 08-23-2012, 04:14 PM   #4
An old Tradesmen
Can really replace. If you remove it, you should then insulate the outside of it.
Old 08-23-2012, 05:24 PM   #5
Is this just old engineering? I understand that thought process for condensation, however I believe it's fiberglass. I am not a engineer, however would this type of stuff be bad in the air. I know that we have felt better since removing it and the previous owner had 2 sick wives over the years. I don't know jsut seems stupid to me.
Old 08-23-2012, 10:21 PM   #6
An old Tradesmen
Wet insulation will grow mold.
Insulated boots/boxes are still sold today.
Tags
boots , hvac , mold , register , vents cleaning
Adding insulation to flex duct tima2381 HVAC 6 06-01-2012 12:29 AM
Is this fiberglass insulation safe (touching heating duct)? nutlog Insulation 6 01-27-2012 07:18 PM
Converting HVAC 10 inch duct to 6 inch HVAC duct Poochie64 HVAC 6 06-05-2011 02:20 PM
Asbestos on ducts and duct supply boots DanGauer HVAC 4 08-31-2010 07:09 AM
Random HVAC duct in garage...help! gone_fishing HVAC 4 07-26-2008 02:04 PM
