HVAC AC In Leaking From Hose - HVAC - DIY Chatroom Home Improvement Forum
Old 06-28-2014, 12:33 PM   #1
HVAC AC in leaking from hose
HVAC unit is in basement. There was a puddle about the size of a gallon or less of water on the floor near the condensate pump. As seen in the pictures, there is one hose (the one dripping) not connected to anything. I am wondering what is came disconnected from. Does it connect to the tee with the other tube going into the pump? I also see a zip tie around the hose and pump. this is from the previous owner and do not know if it is needed. Any help is greatly appreciated.
HVAC AC in leaking from hose-20140628_120120.jpg   HVAC AC in leaking from hose-20140628_120151.jpg   HVAC AC in leaking from hose-20140628_120216.jpg   HVAC AC in leaking from hose-20140628_120245.jpg   HVAC AC in leaking from hose-20140628_120303.jpg
tsolberg is offline   Reply With Quote
Old 06-28-2014, 01:54 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,286
Follow it see where it goes. it may have been the drain for a humidifier that no longer is there?
Old 06-28-2014, 03:10 PM   #3
Rewards Points: 907
It looks like it is going to the trap on the side of the furnace. Have you been running the system in heat mode?
Bitters is offline   Reply With Quote
Old 06-28-2014, 03:39 PM   #4
Rewards Points: 907
Now that I took a second look at the pictures, I think I see what happened. The hose has vibrated out of the pump. That hose should drain into the pump.
Old 06-28-2014, 08:26 PM   #5
Thank you all for the information.
Sprayer hose removal zubby01 Plumbing 0 07-29-2011 12:51 PM
Sprinkler hose leaks LGF Gardening Forum 3 07-16-2011 12:35 PM
Drain hose leaking supermex79 Plumbing 4 05-17-2011 07:19 AM
moving HVAC system - can I go without gas for a few days? denemante HVAC 2 03-30-2011 04:55 AM
HVAC Unit Leaking Water timb10594 HVAC 1 08-26-2009 09:51 AM
