Hvac - HVAC - DIY Chatroom Home Improvement Forum
Old 02-24-2011, 11:36 AM   #1
hvac
Hi. I have a trane xe90 that is flashing two times . I know this means lockout. What can I do to fix this problem .
ErnieP is offline   Reply With Quote
Old 02-24-2011, 11:50 AM   #2
JJboy's Avatar
You need to check the safety switches first.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 02-24-2011, 02:59 PM   #3
Turn the power off and then back on...the furnace will try to restart.
You could have had a burner outage due to the furnace sensing an unsafe condition.
Observe the burners to see if they go out again.
hvaclover is offline   Reply With Quote
Old 02-24-2011, 04:51 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 380
Find the error code on the back of one of the doors or in the owners manual and post it here.
Old 02-24-2011, 07:45 PM   #5
Two blinks soft lock out.
Do I need a HVAC return vent in basement? westing HVAC 13 04-03-2014 01:43 AM
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 07:28 AM
HVAC in out Condo Jzone99 HVAC 10 11-21-2009 04:28 AM
Estimate for Basement HVAC in New Construction jb_nc HVAC 4 07-29-2009 11:48 AM
Engineered Joists & holes for HVAC ducts walt1122 Building & Construction 3 07-04-2009 07:37 PM
