Hvac - HVAC - DIY Chatroom Home Improvement Forum
Old 12-19-2008, 01:06 AM   #1
Question
Hvac
YORK DIAMOND 80 Series
Furnace comes on and then cycles,blower, heat and heater shuts down, then cycles again. after 3 cycles it shuts down and blows only cold air. blower never shuts down. You turn off the furnace then back on, it go's 3 cycles of heating and heat shuts down and blower blows cold air, blower never shuts down. feel it's caused by some type of safty switch, but which one and how to test it
rhilton is offline   Reply With Quote
Old 12-19-2008, 05:02 AM   #2
An old Tradesmen
Rewards Points: 6,132
Most likely the high limit.
It indicates, that either, the air filter is dirty and restricting.
Or, the A/C coil is dirty and restricting.
Or, you have blocked/restricted supplies or returns.
Or, you have alays had low air flow, and the limit switch is wearing out.
Old 12-19-2008, 08:37 AM   #3
Yup, my first thought was your high temp limit switch is tripping. Check all the obvious things first as been has mentioned, then check out that switch.
dac122 is offline   Reply With Quote
Do I need a HVAC return vent in basement? westing HVAC 13 04-03-2014 02:43 AM
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 08:28 AM
HVAC plans for remodel wease HVAC 3 03-23-2011 11:47 AM
HVAC Options-Recommendations? MIMaguire HVAC 17 06-10-2008 08:09 PM
