Hvac - HVAC - DIY Chatroom Home Improvement Forum
Old 05-11-2013, 11:39 PM   #1
hvac
Internal overload. Does anyone no when the overload is tripped were will the open in the windings be. Run start are common? What will the overload take out the loop to couse it not to run.
spider79 is offline   Reply With Quote
Old 05-11-2013, 11:57 PM   #2
biggles's Avatar
on a 230V compressor as in residential either hot leg drops out the compressor will stop but the condenser fan will continue to run with the contactor still in...it could be a klaxon disc within the terminal cover..or an internal winding stat both heat activated...run winding is broken by either
Old 05-12-2013, 12:09 AM   #3
Great thx
Yes my fan was running.
Runaround - HVAC and HWH proper venting/exhaust denemante HVAC 24 04-05-2011 09:50 PM
moving HVAC system - can I go without gas for a few days? denemante HVAC 2 03-30-2011 05:55 AM
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 08:28 AM
Engineered Joists & holes for HVAC ducts walt1122 Building & Construction 3 07-04-2009 08:37 PM
