Hvac - HVAC - DIY Chatroom Home Improvement Forum
Old 04-11-2013, 05:16 PM   #1
hvac
I have a Armstrong gas hot air furnace, model#guk075d14-2b. It runs for about 2minutes fine, shuts off for about 3 minutes, keeps cycling. Changed flame sensor, no help. Hoping circuit board is cure. Any input greatly appreciated. T.y.
Cheapster Diy is offline   Reply With Quote
Old 04-11-2013, 05:50 PM   #2
An old Tradesmen
Rewards Points: 7,330
Dirty air filter/A/C coil/blower wheel/blocked or shut off registers.
Old 04-11-2013, 08:38 PM   #3
Rewards Points: 446
When you say it's shutting off, do you mean the entire furnace shuts off in that short of cycles?
old_squid is offline   Reply With Quote
Old 04-11-2013, 09:08 PM   #4
how
Rewards Points: 1,104
Is it the main flame that goes off every 2 minutes? The inducer motor?
The blower motor?
Do you have a led diagnostic light that's flashing?
how is offline   Reply With Quote
Old 04-11-2013, 09:14 PM   #5
yes, the blower fan shuts off before the system reaches thermostat setting. system starts up again as if it was just turned up higher temp after sitting off for about 3 minutes. burner comes on ,then fan, 2minutes shuts down. does this until reaches desired temp. clean filter and no blocked registers.
Old 04-11-2013, 09:18 PM   #6
System has no diagnostic led light. circuit board may have gotten wet in the past.
Old 04-11-2013, 09:32 PM   #7
how
Hmmm....Water and boards just don't mix.
I'd first confirm that it's not a stat problem by bypassing it at the furnace board.
Turn off furnace power.
Remove the stat wires from R & W where they attach to the furnace board.
Attach a small piece of insulated wire between R & W.
Turn power back on.
If the furnace stays on..it's a stat problem.
If it keeps short cycling like before, reverse what you did with the stat wires and it's on to the next step.
Old 04-11-2013, 09:44 PM   #8
Sorry, but i'm a rookie, whats R&W ? thanks alot
Old 04-11-2013, 09:51 PM   #9
how
If you follow your thermostat wires into the furnace, they will eventually attach to a series of low voltage screws on the furnace board. Those screws positions will be marked with letters.(including R & W) Your thermostat just completes the circuit between those two to run the furnace.
Old 04-11-2013, 09:56 PM   #10
Thanks HOW, i will try that tomorrow.hagn I will post results .
Thinking about installing my own retrofit AC system-with some help from real HVAC guy BT5150 HVAC 2 08-02-2012 06:43 PM
Runaround - HVAC and HWH proper venting/exhaust denemante HVAC 24 04-05-2011 08:50 PM
moving HVAC system - can I go without gas for a few days? denemante HVAC 2 03-30-2011 04:55 AM
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 07:28 AM
