Hvac - HVAC - DIY Chatroom Home Improvement Forum
Old 11-08-2012, 11:57 PM   #1
imayearin's Avatar
Hvac
Pneumatic thermostat is reversed controlled. Turn it to 85 degrees and you get 56 degrees on the coil of wall unit, set it to 55 and you get 117 degrees. This is a refrigerant designed system that was converted to a three pipe chill water/steam system.....if I swap air lines of the hot/cold valves will the thermostat work properly? Assuming the valves are still working properly.
imayearin is offline   Reply With Quote
Old 11-09-2012, 12:09 AM   #2
imayearin's Avatar
Kinda answered my own question, but still interested responses of experienced workers since I'll be working behind people that didn't care lol
Old 11-09-2012, 08:26 PM   #3
An old Tradesmen
Rewards Points: 6,544
Should. I usually check weather I need a direct acting, or reverse acting one before I order a new one in.
The Following User Says Thank You to beenthere For This Useful Post:
imayearin (11-09-2012)
Old 11-19-2012, 09:42 PM   #4
imayearin's Avatar
Omg you are good, the vavles were reversed when installed. Yay 122 degrees into the water chiller and vise versa
Old 11-19-2012, 09:48 PM   #5
He ain't THAT good...he just Googles faster than anybody here.
hvaclover is offline   Reply With Quote
Old 11-19-2012, 10:00 PM   #6
imayearin's Avatar
I'm Kermit the frog green, and had a 20 year vet crying with me today lol
I will post pics someday down the line
Old 11-20-2012, 05:50 AM   #7
An old Tradesmen
Its happened on more then one system.
HELP!!! How much owe my HVAC repairman? Is he competant? MB1 HVAC 23 02-01-2012 03:42 PM
Runaround - HVAC and HWH proper venting/exhaust denemante HVAC 24 04-05-2011 09:50 PM
moving HVAC system - can I go without gas for a few days? denemante HVAC 2 03-30-2011 05:55 AM
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 08:28 AM
Engineered Joists & holes for HVAC ducts walt1122 Building & Construction 3 07-04-2009 08:37 PM
