Old 11-05-2012, 08:34 PM   #1
Hvac
Im having trouble with a Lennox furnace, there is two together and the twinning module is disconnected. I ran my thermostat wires to the one furnace and it would not come the led light is flashing normal and the induce draft fan is running but there is no call for heat.
biggzeke is offline   Reply With Quote
Old 11-05-2012, 09:35 PM   #2
An old Tradesmen
Hvac
Moved to HVAC forum.
Old 11-05-2012, 09:50 PM   #3
I'm Your Huckleberry
Hvac
Appears to be obvious that heat call/wire is missing.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 11-05-2012, 09:58 PM   #4
Hvac
jump the r and w terminals on control board to see if you get ignition of furnace...ben sr
Old 11-05-2012, 10:04 PM   #5
Hvac
With the twinning kit removed one blower will run backwards and trip the limit behind the blower.
Old 11-05-2012, 10:09 PM   #6
Hvac
maybe......
carmon is offline   Reply With Quote
Old 11-05-2012, 11:05 PM   #7
Hvac
The thermostat works with the other furnace the led ia reading normal when it should be flashing for a call for heat. The blower on this furnace has been jumped and,its just blowing.
Old 11-05-2012, 11:16 PM   #8
Hvac
blower jumped and its blowing.... well then ....that's good.... what about when you jump r-w.....
The Following User Says Thank You to carmon For This Useful Post:
ben's plumbing (11-06-2012)
Runaround - HVAC and HWH proper venting/exhaust denemante HVAC 24 04-05-2011 09:50 PM
moving HVAC system - can I go without gas for a few days? denemante HVAC 2 03-30-2011 05:55 AM
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 08:28 AM
Engineered Joists & holes for HVAC ducts walt1122 Building & Construction 3 07-04-2009 08:37 PM
