Hvac - HVAC - DIY Chatroom Home Improvement Forum
Old 09-23-2012, 12:31 PM   #1
hvac
wireing new fan motor old has 3 wires orange /black/brown new has orange/brown /black/yellow/purple so wuz up help wat goes to watt thanks
dads? is offline   Reply With Quote
Old 09-23-2012, 12:40 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
I'm assuming blower motor? There should be a wiring diagram on the side of the motor. It sounds like your old motor was single speed (rare for a psc blower motor) and the new motor has 3 speeds. What is the model of equipment it is going in? Where did the old wires hook up? Pictures? Need more info...
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 09-23-2012, 12:57 PM   #3
its in a rheem new motor is recomended replacement thought simple hook colors to colors have 2 extra s purple /yellow blower has countewr clockwose rotation
Old 09-23-2012, 01:00 PM   #4
AKA HVACTECHFW
still need more info. model number - motor and or furnace? pictures?
IT IS WHAT IT IS
Old 09-23-2012, 01:41 PM   #5
Read the label on your old motor. It should say CW or CCW (counter clockwise)
When I replaced my Trane blower motor with a Dayton motor, it also had that yellow/purple wires but they did not get attached to the furnace at all.
It simple had a reversible plastic connector that allowed you to change the direction to match the old motor. Mine was:
CW
PURPLE -- PURPLE
YELLOW -- YELLOW
CCW
PURPLE -- YELLOW
YELLOW -- PURPLE
Good luck
PS. Your capacitor will still be charged so be careful and don't touch those terminals!
OLD
NEW
allthumbsdiy is offline   Reply With Quote
Thinking about installing my own retrofit AC system-with some help from real HVAC guy BT5150 HVAC 2 08-02-2012 06:43 PM
Runaround - HVAC and HWH proper venting/exhaust denemante HVAC 24 04-05-2011 08:50 PM
moving HVAC system - can I go without gas for a few days? denemante HVAC 2 03-30-2011 04:55 AM
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 07:28 AM
Engineered Joists & holes for HVAC ducts walt1122 Building & Construction 3 07-04-2009 07:37 PM
