#1 |
Hvac
the rental condo I live in has an electric Bryant unit that is probably 20 years old or so. The outdoor unit freezes over completely around the grid when the temps drop and the coils get covered over with a couple of inches of ice. It doesn't melt unless the temps warm up outside and/or the sun comes out.
Inside the thermostat has to be set at a higher temp to get it to what you want it. The auxiliary kicks in often when the coils are frozen, causing my electric bills to go up. Can you tell me if this is standard for these units? |
#2 |
HVAC Tech/ Browns Fan
Hvac
It maybe low on freon or Defrost board is bad. You need to get it looked asap!! You will have a very high electric bill!!!
#3 |
Hvac
You need put on Back up heat for the night and call hvac company in the morning.
#4 | |
HvacQuote:
| The Following User Says Thank You to ben's plumbing For This Useful Post: | Cadence61 (02-29-2012) |
#5 |
Hvac
Thanks Tator. It has already been checked and they replaced the sensor board and added a couple of pounds of freon. It worked for about 10 days and it broke again. But the landlord doesn't want to do anything else to it.
#6 |
Hvac
That's what I've been telling the landlord :-/ but not getting anywhere. I just wanted to make sure I wasn't making and issue where there's none.
Thanks! |
#7 |
Hvac
Will looks like you need find new place to go if he don't replace it. It has a leak and need replace system. You are going to have very high bills if he don't replace it.
| The Following User Says Thank You to Tator1076 For This Useful Post: | ben's plumbing (02-29-2012) |
#8 |
Hvac
If he added a couple pounds of freon and didn't fix the leak then he might just as well have bleed the freon into the air.What he did has the same effect.
There are landlord,tennet laws in most areas .If your area has them then it will state what the landlord is responsible for and what you can hold back from the rent until he does his responsibility in a holding account. |
#9 |
Hvac
Most company's are only allowed to fill it so many times. We fill it once then next time you must have leak check and repair done or replacement before recharge.
| Display Modes | |
| HELP!!! How much owe my HVAC repairman? Is he competant? | MB1 | HVAC | 23 | 02-01-2012 03:42 PM |
| Runaround - HVAC and HWH proper venting/exhaust | denemante | HVAC | 24 | 04-05-2011 09:50 PM |
| moving HVAC system - can I go without gas for a few days? | denemante | HVAC | 2 | 03-30-2011 05:55 AM |
| History of HVAC Industry Brands | winkydink | HVAC | 8 | 03-25-2011 08:28 AM |
| Engineered Joists & holes for HVAC ducts | walt1122 | Building & Construction | 3 | 07-04-2009 08:37 PM |
