Hvac - HVAC - DIY Chatroom Home Improvement Forum
Old 12-13-2011, 11:17 AM   #1
Question
hvac
i have a goodman gmp 100-3 furnace and it shuts itself off and all i have to do is turn off power swithh and turn on and the furnace starts. it sounds like a limit or auto resetabale safty switch ???????.the furnace usually doesnt turn on in morning when the programable thermostst turns it on. I must go down and turn power on and off
thanks for the help
paul
paulat120 is offline   Reply With Quote
Old 12-13-2011, 02:32 PM   #2
Willing to listen
Rewards Points: 215
Does it's control board have an led and are there any fault codes present?? On some lower end stuff you purge the faults when you cycle power...no permanent memory storage & recall.
Done That is offline   Reply With Quote
Old 12-13-2011, 04:34 PM   #3
An old Tradesmen
Rewards Points: 6,148
GMP, it probably has a cracked heat exchanger.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
ben's plumbing (12-13-2011), paulat120 (12-13-2011)
Old 12-14-2011, 09:13 AM   #4
this is a furnace not a heast pump. it has a seperate evaporator for ac. the priblem only happens with heat
Old 12-14-2011, 09:17 AM   #5
hard to say since when i remove lower cover of furnace to control board the door switch shuts off power and then it is already reset when switch is depressed thanks
paul
Old 12-14-2011, 11:58 AM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 1,158
put a piece of ducttape on the door switch so it stays closed when you open the door.
The Following User Says Thank You to yuri For This Useful Post:
paulat120 (12-14-2011)
Old 12-14-2011, 06:02 PM   #7
thanks yuri Ill try taping door switch.
Old 12-14-2011, 06:07 PM   #8
Hvac Pro
yuri's Avatar
Shhh, it's a trade secret.
Old 12-14-2011, 06:27 PM   #9
An old Tradesmen
Most GMPs have a cracked heat exchanger.
Old 12-15-2011, 10:33 AM   #10
indicator lights on goodman gmp 100-a
i found that the lower led lights are blinking 3 times .what does that mean also I shut heat off by thermostal last night and it should have turned on by thermostat at 7AM and when I checked at 8 the unit was off and the led was blinking 3 times. any hints appreciated
paul
thanks paul
Old 12-15-2011, 10:45 AM   #11
goodman gmp
shut unit off by thermost last night and it should have turned on automatically this morning at 7AM but when I looked at 8 it was not on and the led on lower unit control board was blinking 3 times
any hints thanks
Paul
Old 12-15-2011, 07:46 PM   #12
Hvac Pro
yuri's Avatar
look on the back of one of the doors or by the wiring diagram for a list of codes
Old 12-15-2011, 09:50 PM   #13
Rewards Points: 484
paul
thanks paul
Beenthere mentioned possible heat exchanger problem twice. Get it checked!
sammy37 is offline   Reply With Quote
Old 12-15-2011, 09:54 PM   #14
Rewards Points: 582
already know that one to late...he he have one in the back of the truck now with cracked heat exchanger....get it checked as beenthere said...
Old 12-16-2011, 08:22 AM   #15
Willing to listen
Rewards Points: 215
Google "GMP100-3 Installation and wiring" it's pretty easy to find their lit on the web.
And listen to what the pros on here are telling you about experience with cracked heat exchanger on this model, they would know...
Runaround - HVAC and HWH proper venting/exhaust denemante HVAC 24 04-05-2011 09:50 PM
moving HVAC system - can I go without gas for a few days? denemante HVAC 2 03-30-2011 05:55 AM
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 08:28 AM
Engineered Joists & holes for HVAC ducts walt1122 Building & Construction 3 07-04-2009 08:37 PM
