Hvac - HVAC - DIY Chatroom Home Improvement Forum
Old 10-22-2011, 07:13 PM   #1
PJP
hvac
i have ducane furnace and it lites and goes out replced flame sensor and control board and still does it. has fault code 6+5 flame sense out of sequence
PJP is offline   Reply With Quote
Old 10-22-2011, 07:32 PM   #2
PJP
same as fault 5 flame sense should not be present
Old 10-22-2011, 07:40 PM   #3
PJP
would the honeywell smart valve be the problem
Old 10-22-2011, 08:13 PM   #4
An old Tradesmen
Rewards Points: 7,384
Could be.
Old 10-22-2011, 09:02 PM   #5
PJP
have you ran into this before
Old 10-22-2011, 09:20 PM   #6
I'm Your Huckleberry
Rewards Points: 2,270
You're new so I'll go ahead and tell you. "Beenthere", as his screen name suggests, has seen everything hvac and more than once and not just residential furnaces either. Ask him about boilers, radiators, hydronics, you name it. Seriously.
The dOod is like The Jedi Knight when it comes to fixing things, he's definitely "beenthere".
Myself, not so much...
Doc Holliday is offline   Reply With Quote
Old 10-22-2011, 09:45 PM   #7
PJP
thank you verry much i just dont want to spend money on house that i dont own got a slum lord
Old 10-23-2011, 04:23 AM   #8
An old Tradesmen
The Smart valves have had a problem since they came out.
New flame sensor not working
Old 10-23-2011, 09:21 AM   #9
PJP
no after cleaned the old one and installed it and had same results i bought a new one and installed same results. was checking around found a burn mark on the control board and replaced with the same results
Old 10-23-2011, 10:08 AM   #10
I think what he's saying is to replace the smart valve. The signal is being sent through it in place of the flame sensor, possibly.
Old 10-23-2011, 12:30 PM   #11
An old Tradesmen
The valves board may have a short in it.
PS: The law in all states requires that a landlord have the heat repaired in any property thy rent out for residential occupancy. Call him, he has no choice but to either fix it himself, or call a company in to fix it.
The Following User Says Thank You to beenthere For This Useful Post:
Doc Holliday (10-23-2011)
Old 10-25-2011, 05:55 PM   #12
PJP
thank you very much beenthere , if you ever need help with vehicle let me know automotive tech 30yrs.
Old 10-25-2011, 09:48 PM   #13
If beenthere is a jedi knight, I want to be Darth Vader.
Master of Cold is offline   Reply With Quote
Do I need a HVAC return vent in basement? westing HVAC 13 04-03-2014 01:43 AM
Runaround - HVAC and HWH proper venting/exhaust denemante HVAC 24 04-05-2011 08:50 PM
moving HVAC system - can I go without gas for a few days? denemante HVAC 2 03-30-2011 04:55 AM
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 07:28 AM
Engineered Joists & holes for HVAC ducts walt1122 Building & Construction 3 07-04-2009 07:37 PM
