Old 11-21-2007, 10:51 PM   #1
Hunter Thermostat Problem
I replaced an older thermostat with a new hunter digital model model 44110 a couple of years ago. It worked fine until this spring. I had already turned the system switch to "OFF" and tried to turn back to "HEAT" on a colder day and the furnace wouldn't fire. I didn't mess with it at the time, but later pulled the cover off and found that a "FUSE" of some kind had exploded on the back. Assuming this had been a glitch in the thermostat, I purchased an identical model a few days ago so I wouldn't have to re-wire and simply "plugged" the new cover and circuit board in....Still, no heat. So I switched it to cool and the thing exploded again, but the A/C stayed on.
Any idea why this would be happening?? I found that the the W (heat) and Y (air conditioning) wires were a little loose at the thermostat. I've tightned them to make sure the connection is good, but was wondering if that alone could have caused the "blow up" on my thermostat.
Any insight would be appreciated.
kohlernm is offline   Reply With Quote
Old 11-22-2007, 10:58 PM   #2
Sounds like u have a short somewhere. Check thermostat wires to the unit. If you say it looks like a blown fuse, it's a blown fuse. If you say it looks like a blown circuit board, it's blown circuit board . Obviously fuses are safety devices that protect circuit boards and other delicate parts. Be careful and good luck. Cliff
UBoiler is offline   Reply With Quote
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
2 stage heat thermostat problem W1 AND w2 wires whatdoIdonow HVAC 6 11-26-2006 01:04 AM
A/C Thermostat Problem therumblefish HVAC 7 11-01-2006 09:08 PM
Thermostat Wiring Problem crazy woman HVAC 2 08-15-2006 10:22 AM
