Hunter Thermostat 44860 Issue - HVAC - DIY Chatroom Home Improvement Forum
Old 05-12-2013, 10:19 PM   #1
okay --- so here's the thing. my idiot husband got pissed off because i locked the thermostat and he yanked it off the wall.
now i am trying to install a new one (a Hunter 44860 which was the same one we had before). but, we aren't sure where the wires go now. somehow i have a brown wire that they never had hooked up. and the directions are for 3, 4, 5 or 7 wire installations and i only have 6. i put the wires back where they were at in the first place, but now it doesn't work.
does anyone have any idea about what goes where? I have uploaded a couple of pics to show you guys.
Hunter Thermostat 44860 Issue-2013-05-12-20.58.04.jpg   Hunter Thermostat 44860 Issue-2013-05-12-20.58.18.jpg
urbaneve is offline   Reply With Quote
Old 05-12-2013, 10:28 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
If nothing works then you likely have a blown fuse or transformer in the air handler, furnace, or package unit (depends on what kind of system you have).
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 05-12-2013, 11:19 PM   #3
Rewards Points: 6,652
Start by going to the furnace and verifying what colored wire goes to what terminal down there. As for locking out the thermostat and the hubby yanking it off the wall, suggest seeking a marriage counselor, due to there is more at hand here, than a controlling wife/partner.
The Following User Says Thank You to gregzoll For This Useful Post:
hvactech126 (05-12-2013)
Old 05-13-2013, 07:10 AM   #4
Rewards Points: 582
if you r husband yanked it off the wall....my guess as mentioned low voltage fuse is blown...ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
hvactech126 (05-13-2013)
Old 05-13-2013, 05:22 PM   #5
I checked the furnace and checked all that.... it appears that they changed the unit out and when the previous owner put in the new one --- he spliced wires together, so the color coding thing is kinda out the window.
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 05:32 PM
Line Volt Thermostat issue ctct000 Electrical 4 02-05-2011 10:06 AM
Thermostat issues rathipon HVAC 4 01-29-2011 12:46 PM
Wiring on Hunter Analog Thermostat woomama HVAC 16 03-22-2010 02:52 PM
Upgraded to new Hunter model 44860 thermostat and now no emergency heat hlmaint HVAC 0 01-08-2010 02:17 PM
