Old 10-18-2009, 07:57 PM   #1
Default Hunter 44668 Thermostat - Heat won't turn off
I just replaced a Hunter Auto-Temp II thermostat (44428, I think) with a 44668 with remote temp sensor. The system is a Goodman PH036-1a, about 12 years old now.
I replaced the thermostat about 2 months about two months ago, wiring it for a SSHP set-up. I wired it by color, and initially had some problems since the old version didn't have the Rc/Rh jumper. But I got the AC system to work.
Now, the temperature has dropped, and the heat came on for the first time. Except that the heat didn't stop when the thermostat limit was reached. I reset the thermostat a couple of times, with no change. I can turn the whole system on or off via the thermostat still.
ToneyRes is offline   Reply With Quote
Old 10-18-2009, 08:49 PM   #2
Master Plumber/Mechanical
Cool
Just my $.02
Hunter stats are the worst..they are good for fishing weights though
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Arcoaire and Trane Dealer
Old 10-18-2009, 08:57 PM   #3
old pro
Wouldn't give you $.01 for one. They do create work and $$ revenue for us. Hard to convince people they get what they pay for.
Old 10-18-2009, 09:08 PM   #4
Houston204's Avatar
What I've found so far is, that's not a multistage heatpump stat.
If you put your auxillary heat wire on the W/B terminal, and set the toggle to SSHP, it will energize the heat strips the entire time it is in heat mode regardless of stat setpoint.
Houston204 is offline   Reply With Quote
Old 10-18-2009, 09:29 PM   #5
Houston204's Avatar
I recommend a Honeywell RTH7400, RTH7500 or RTH7600.
Old 10-18-2009, 09:38 PM   #6
old pro
It gets HOT in Texas. I am watching Extreme home makeover and they are building there. WOW.
Old 10-18-2009, 10:01 PM   #7
Houston204's Avatar
The summer heat won't let go this year. I feel bad turning off my customers' AC to test the heat for our prepaid mc accounts.
That backdraft lockout call was impressive Yuri.
Old 10-18-2009, 10:15 PM   #8
old pro
We had 2 inches of snow last week. Too bad it melted or I could have FedEx some to you in a Coleman cooler. LOL
Old 10-18-2009, 10:35 PM   #9
sktn77a's Avatar
Are you absolutey sure its wired correctly (especially the reversing valve) and setup correctly in the thermostat options and setup? And the switch is set to SSHP? The thermostat should work (albeit without Aux heat). Maybe just a bad thermostat.
sktn77a is offline   Reply With Quote
Old 10-18-2009, 10:50 PM   #10
Houston204's Avatar
If you have Aux heat. It won't work correctly for your system.
You can get partial operation by removing the wire from the W/B terminal, but you need a different stat, since it will not support your stage 2 heat.
More On This Topic
Today we are replacing a bad thermostat. Now once you have it removed from the wall, you’ll have to scrape this and repaint it, I’m sure. But you want to make sure to get the right thermostat because you can cause some damage to your A/C or... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, I will be talking about locating and replacing your thermostat. The first step to locating your thermostat is to locate the large tubes coming out of your radiator. On this particular car... Read More »
Nothing can ruin your summer or winter like finding you have no heat or air conditioning because your heat pump is malfunctioning. If you have to buy a new heat pump, an uncomfortable season can turn into an uncomfortable year. However, heat pumps are... Read More »
Before you call someone to come fix your furnace, you may want to find out what's wrong. Read on to learn how to check your furnace for any possible malfunctions. Read More »
The thermostat on your wall that controls your HVAC system is the key to your comfort. Knowing how it interfaces with your heating and air conditioning system can help you stay comfortable during long, cold winters and hot, sweltering summers. A key part... Read More »
Programmable thermostats, heat pumps and aux heat Crunkleton HVAC 3 04-21-2009 07:17 PM
Thermostat and emergency heat relay kulkarni_ash HVAC 0 10-10-2008 11:34 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 09:40 AM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 04:11 PM
no heat when turn furnace on atl HVAC 1 10-24-2006 02:38 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
