Old 02-03-2013, 03:13 PM   #1
Hunter 44132 thermostat to a Rheem AC
I'm trying to connect a 5 minute universal hunter 44132 thermostat . I have a brand new Rheem AC. Need wiring advice. On the hunter in order it's R, Y, G, L, O, B, A/E, Y2, C. The wire colors coming out the wall are Red, yellow, green, blue, orange, and white.
I've tried two wiring methods so far and I can't get air to blow through the vents. What do you suggest?
Jean Fallout is offline   Reply With Quote
Old 02-03-2013, 08:02 PM   #2
Experienced HVAC Tech
HVAC1000's Avatar
did you write down which wires were in which terminals on the old thermostat. it will depend on where the wires are connected to on the air handler unit. just cause a wire is red doesnt mean it was connected to the R terminal. they are just colors to help avoid confusion on which wire is which. check at the unit because the installer could have done something funky.
HVAC1000 is offline   Reply With Quote
Old 02-03-2013, 08:09 PM   #3
No. The installer and his buddy had a disagreement so both fooled with the thermostat, and it was not functioning correctly. I bought a new one because I didn't trust that the thermostat they used worked properly. They both fiddled with the wires and changed them around so it's a mess. I have to get an electrician in or fix this myself.
Old 02-03-2013, 09:26 PM   #4
An old Tradesmen
Rheem A/C, or is it a heat pump.
Old 02-03-2013, 09:33 PM   #5
HVAC1000's Avatar
you dont need to call an electrician. they tend to know as much about this kind of control system as you do, if you call in any professional call an HVAC tech who is certified in Heat Pumps. you need to check the wiring at the unit then wire it up the same at the stat. are you sure you got a compatible tstat for your system?
Tags
hunter, wiring.
Wiring help for new Hunter 44132 thermostat Wcavin HVAC 6 09-04-2011 07:51 PM
Wiring on Hunter Analog Thermostat woomama HVAC 16 03-22-2010 02:52 PM
Upgraded to new Hunter model 44860 thermostat and now no emergency heat hlmaint HVAC 0 01-08-2010 02:17 PM
Hunter 44668 Thermostat - Heat won't turn off ToneyRes HVAC 9 10-18-2009 09:50 PM
Hunter Thermostat Problem kohlernm HVAC 1 11-22-2007 10:58 PM
