Old 08-24-2010, 12:21 PM   #1
Humming noise when air handler turns on
Hi,
I have an annoying low pitch humming noise whenever the air handler turns on. The noise is coming from the unit in the attic but can be heard throughout the house. The A/C technician has already come out and replace the motor but the noise is still there. It only comes on right when the air handler starts blowing. Any suggestions?
Thanks.
redfish99 is offline   Reply With Quote
Old 08-24-2010, 12:44 PM   #2
fabrk8r
fabrk8r's Avatar
Is the unit suspended from the rafters or is it sitting on the ceiling joists?
Some times the vibration can be transmitted through the building structure if the unit isn't properly isolated.
Otherwise it may be an air leakage problem causing a whistling sound or perhaps a blower wheel problem.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Rattling Noise from Roof when windy drgillian Roofing 3 02-18-2011 10:05 AM
Central air (outside unit) makes strange noise when it turns off. Am I in trouble? Player HVAC 6 07-12-2010 08:49 PM
Noisy furnace (with recording of noise) Jeffrey HVAC 3 01-23-2010 02:17 PM
Trane 1100 XE- Outside unit making humming noise Momof2 HVAC 0 09-03-2009 12:25 PM
Loud humming noise from electric forced air furnace MissBehavin HVAC 9 01-02-2009 06:14 PM
