Humming Freon Line. - HVAC - DIY Chatroom Home Improvement Forum
Old 01-05-2006, 10:24 AM   #1
Humming freon line.
I have a new 4 ton heat pump system with an annoying hum.
The A coil, outside unit and froen line have all been replaced.
None has helped.
Is this something you have to live with?
Are any brands less prone to this than others?
carson2 is offline   Reply With Quote
Old 01-10-2006, 07:53 PM   #2
weinstall.ca
Post
None has helped.
Make sure that there is no cement around the pipe as it enters the room.
Use putty instaead
Hang your pipe on rubber bands, Make sure your unit has rubber isolaters under the condensor.
And make sure who ever charged the unit did not over charge it with too much freon.
Allan Thorne
Clarkson Comfort Zone Heating
weinstall.ca
allan is offline   Reply With Quote
3/4" gas line needs to be bigger raymond_anthony HVAC 11 10-28-2009 06:59 PM
ac suction line placement? nimbenja HVAC 8 10-28-2009 06:43 AM
Condensate Line schott HVAC 17 06-02-2008 04:16 PM
how to run fridge water line under kitchen floor? travishume Plumbing 23 09-26-2006 08:51 AM
Installing exterior faucet to washer line? skellies Plumbing 3 06-18-2006 09:19 PM
