Humming Droning Sound When AC Is Running - HVAC - DIY Chatroom Home Improvement Forum
Old 07-06-2011, 09:51 PM   #1
Rewards Points: 18
humming droning sound when AC is running
My air conditioning unit is five years old and was professionally installed. My house is 45 years old. This cooling season, a new sound has developed in one room in the house. It occurs when the AC is running. The sound is a droning/humming sound coming from the vents. The closest sound to compare is semi tires on asphalt. I only hear the sound in this specific room. Don't know if this makes a difference but the room with the sound is the room furthest away from the outside AC unit.
Any ideas of what is causing this sound and what I can do to make it go away?
green.willow is offline   Reply With Quote
Old 07-07-2011, 10:39 AM   #2
is there a return in this room? if so, take off the grill and see if it stops. sometimes there is an air flow thru noise. a larger grill opening can fix this
cascadehvac is offline   Reply With Quote
Old 07-07-2011, 10:12 PM   #3
Rewards Points: 18
Thanks. The weather has cooled so the AC is not running at the moment. I'll give it a try over the weekend and let you know. Your suggestion sort of makes sense.
Tags
air conditioner sound hum
Insulation with Sound Isolation Clips atmironov Building & Construction 12 05-06-2010 04:44 PM
humming sound from wiring in the ceiling to a light fixture njvcl Electrical 3 05-12-2009 11:00 AM
Soundproof Windows BlueJello General DIY Discussions 3 11-30-2007 06:34 PM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 11:22 AM
Leaky Water Sound 24/7, need your advice. clue89 Plumbing 1 03-02-2007 08:36 AM
