Humidity Question - HVAC - Page 5 - DIY Chatroom Home Improvement Forum
Old 04-10-2013, 09:42 PM   #61
An old Tradesmen
Rewards Points: 6,140
Originally Posted by mmiller View Post
how do you post pictures on here?
If you upload it to a hosting service. You can click on insert image at the top of he posting window(what we type in). And insert the link to it.
Old 04-10-2013, 10:27 PM   #62
Ok, so my chimney gas insert even though its a direct vent it still relies on natural draft for the venting? I guess I keep confusing all direct venting with fan assisted venting but I have seen direct vent fireplaces that vent horizontally so those have to be fan assisted. I noticed a tank water heater that had a power vent but from I saw it was not direct vent. It had a small draft assembly with a cover on it to take in air from the room. Do you think these have heat exchangers in them or do only tankless have heat exchangers?
mmiller is offline   Reply With Quote
Old 04-10-2013, 10:35 PM   #63
An old Tradesmen
Your insert uses the liner as a natural chimney.
Yes, a horizontal would have a fan for exhaust.
That water heater was either a direct vent, or a power vent unit.
All water heaters have a heat exchanger. The tank will have a passage way for the combusted gas to travel through and give up its heat to the water. The water heater tank is part of the heat exchanger.
Old 04-10-2013, 11:04 PM   #64
Mine is a natural draft water heater. By heat exchanger I mean like the metal or steel type in a furnace. I know tankless ones have them so they can product constant hot water.
Old 04-11-2013, 05:48 AM   #65
An old Tradesmen
Tankless boilers and water heaters all use coils for their heat transfer. Hot air furnaces don't have a heat exchanger like it due to the blower energy it would require to force air through them.
Old 04-11-2013, 08:55 PM   #66
When you have a metal chimney chase that runs in the attic your supposed to put down some flashing on the attic floor around the opening then seal it and keep insulation away. What does the metal flashing serve as? Is it a moisture and air seal? Also, are you supposed to insulate the actual chase to prevent heat loss and condensation in summer when its not used?
Old 04-11-2013, 09:01 PM   #67
An old Tradesmen
The metal flashing is to act as a thimble. Its to support the chimney.
Old 04-11-2013, 10:37 PM   #68
isn't it to keep a distance between the chase and combustibles? Also, did you get my question about the insulation?
Old 04-12-2013, 05:06 AM   #69
An old Tradesmen
Yep, keeps clearance from combustibles also. Insulation is also kept off of it.
Old 04-12-2013, 10:09 AM   #70
So the actual chase itself from the attic floor to roof. The round pipe you do not insulate at all?
Old 04-12-2013, 04:02 PM   #71
An old Tradesmen
No need to insulate it. Unless its a very long run from the attic floor/joist to the roof.
Old 04-12-2013, 04:51 PM   #72
What about the heat from the chase and cool air in winter. Wouldn't that cause possible condensation?
Old 04-12-2013, 06:53 PM   #73
An old Tradesmen
Condensation where? In the chase, no. On the outside of the chase, no.
Lack of heat(temps below the dew point) is what causes condensation.
Old 04-12-2013, 10:04 PM   #74
When you have the cold attic air and the heat from the chase? Cold always drifts towards warm.
Old 04-13-2013, 06:46 AM   #75
An old Tradesmen
Insulation doesn't prevent the something from getting cold/loosing heat. it only slows down the process.
Most chimney liners are not insulated, as it does more harm then good. Since the cold insulation prevents the liner from getting warm as fast.
window condensation kmpittman Windows and Doors 4 11-29-2011 10:10 AM
sweating double pane windows etch Windows and Doors 6 10-31-2011 10:30 PM
Honeywell IAQ thermostat and humidity control GhostBuster HVAC 14 12-19-2008 01:28 AM
Need to reduce humidity in house creamaster HVAC 4 11-19-2008 05:03 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
