Humidity Question - HVAC - DIY Chatroom Home Improvement Forum
Old 03-26-2013, 09:35 AM   #1
copper
Humidity Question
I live in a single story ranch with a full unfinished basement. Humidity downstairs is near 70% and upstairs is around 50%. I need a dehumidfier downstairs and a humidifier upstairs. Is there a way to move the humidity from downstairs to upstairs without buying these two seperate devices? My heating/cooling system is a GEO unit on an open loop and I only condition the upstairs until I finish the downstairs, which is years away.
Gerb10 is offline   Reply With Quote
Old 03-26-2013, 10:01 AM   #2
Rewards Points: 6,652
It is too high downstairs. It should be at around the same as upstairs. You have some serious issues of either no air exchange from inside to out with the place being too tightly sealed, or a poorly air sealed home.
Old 03-26-2013, 11:23 AM   #3
Rewards Points: 32
I can't think of a way without mixing the air between the basement and upstairs which you don't want to do. You wind up conditioning the air in the basement. An energy star rated dehumidifier doesn't cost that much to run. Off the top of my head, I think 50% humidity is a good number for the winter. Too much higher and you can have condensation issues.
djlandkpl is offline   Reply With Quote
Old 03-26-2013, 12:04 PM   #4
copper
It just seems so dry upstairs, I run a small humidifier in the bedroom at night to help combat it. Seems like you should be able to somehow use the moist air downstairs to aliviate the upstairs dryness. Dehumidifiers for our size basement typically cost between $200-$300. I just wanted to research this option prior to purchasing a dehumidifier. Thanks for the responses!
Old 03-26-2013, 12:12 PM   #5
If it is the basement that has high humidity, you need to seal around the joist perimeter and insulate. You also need to make sure that the HVAC system is able to have a output and return to help keep that space conditioned like the rest of the home. Otherwise, you end up with mold & mildew down there, and wood rot from too high of a humidity level.
Old 03-26-2013, 12:49 PM   #6
Rewards Points: 32
I know it's crazy. I have to do the same. Dehumidifier in the basement, humidifier on the furnace. Once you get the humidity level down to a reasonable level, the unit should not run as long unless you have leakage. Then you should seal as Greg suggests.
You may want to consider two smaller dehumidifiers instead of one depending upon how big a space it is. Also, if the space gets below 50 degrees, you need to get one that will work in cold temperatures. It's been my experience that dehumidifiers don't last long. 2-4 years tops, so don't buy the Cadillac.
You "could" take the basement moisture and move it upstairs but it would be the same as running a dehumidifier and humidifier.
The dehumidifier would take the water out of the air, send it to the humidifier connected to your air handler.
Old 03-26-2013, 03:37 PM   #7
An old Tradesmen
Rewards Points: 7,316
What temp is your basement and first floor. 50% almost makes it sound like your hydrotherm is inaccurate.
Old 03-26-2013, 08:14 PM   #8
Rewards Points: 952
Yeah, are you sure your hygrometers are accurate? Have you switched them from upstairs to down?
I would beg to differ about a dehumidifier being inexpensive to operate. You may find it less expensive to just open a return near the furnace and a supply on opposite sides of the basement.
cleveman is offline   Reply With Quote
Old 03-26-2013, 09:13 PM   #9
how
Rewards Points: 1,104
Humidity levels in a home idealy are kept between 30 - 50 %. Why is it so high downstairs????
Does your basement have heating and return air ducts so that the furnace fan can mix the upstairs and downstairs with a low speed fan operation?
how is offline   Reply With Quote
Old 03-26-2013, 09:39 PM   #10
Rewards Points: 952
I like my humidity at 55 if possible. Below 45 and your nose starts to crack open and your skin as well. This leaves a super highway for infections to get in your body.
Old 03-27-2013, 04:23 AM   #11
An old Tradesmen
The inside corners of your outside walls will be a lower temp then the rest of your house. This is here the humidity will often be the highest. So if you keep your humidity at 55%, those areas can exceed 60% and can cause mold growth.
Old 03-27-2013, 08:49 AM   #12
Rewards Points: 1,236
What's the problem with conditioning the basement? According to manual J the load is zero on a completely underground basement.
SeniorSitizen is offline   Reply With Quote
Old 03-27-2013, 03:30 PM   #13
An old Tradesmen
Never seen a Manual J say that a completely underground basement is zero BTU loss.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (03-27-2013)
Old 03-27-2013, 05:11 PM   #14
I probably shouldn't have written zero. Sorry about that.
beenthere
09-01-2010, 06:12 PM HVAC Talk
Unless its a real big basement. or has lots of air leakage. A basement doesn't need much heat(completely below grade basements that is).
The ground temp is 55, so you don't have much of a load, and often, some contractors will say no load.
Old 03-27-2013, 05:33 PM   #15
An old Tradesmen
beenthere
Not much of a load. But still a load. A 1200 sq ft completely under ground/below grade basement with a ground temp of 55 will usually have a heat loss between 6,000 and 12,000 BTUs.
caulking old wood windows andyman Windows and Doors 10 12-31-2011 03:39 PM
window condensation kmpittman Windows and Doors 4 11-29-2011 09:10 AM
Honeywell IAQ thermostat and humidity control GhostBuster HVAC 14 12-19-2008 12:28 AM
Need to reduce humidity in house creamaster HVAC 4 11-19-2008 04:03 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
