Humidity Help - HVAC - DIY Chatroom Home Improvement Forum
Old 06-23-2011, 09:21 PM   #1
Rewards Points: 252
Humidity help
The humidity levels in my home are an absolute mess!!!
Our home is located in ny and we have a two story house with a finished basement. The house is 30x50 and the ac is separated in two zones - no ac in the basement. Our air handlers are in the attic. Our heating is mostly hot water baseboard - although we are converting some rooms to radiant.
The problem is our house gets very dry in the winter and extremely humid in the summer. Right now our humidity levels are around 75% and in the winter we are usually around 25%. Last winter we had an aprilaire Bypass humidifier installed in our attic on our air handler that handles the top floor. A hot water line was run into the attic and I basically had the fan run constantly. Problem is the pads in the humidifier went bad very fast - weeks - because there was no hot air to dry out the pads. Also - I hate having a water line in my attic. The humidity level did come up a little but I fel the system was working very hard for such a small gain.
So bottom line - is there anything I can do here? I contacted the company that makes that wave ventilation unit to see if that might do something. Besides that I am at a loss.
mazzonetv is offline   Reply With Quote
Old 06-23-2011, 10:24 PM   #2
What type of ventilation does the attic have coming out the roof of the house?
roofie is offline   Reply With Quote
Old 06-24-2011, 04:45 AM   #3
An old Tradesmen
Rewards Points: 7,292
Seal your house up better. Its the infiltration of outside air that is causing most of your humidity problems.
And unless your water heater is close to your humidifier, at only 6 gallons an hour, the water reaching the humidifier is not hot enough to provide good humidification. In an application as you describe, the water needs to be 140F.
Old 06-24-2011, 05:40 AM   #4
Rewards Points: 252
There is an attic fan up there. Could the air handlers be pulling the humidity in from the attic and circulating that around the house?
As far as water temp goes - I though about that but the water to the humidifier is actually feeding from right above the boiler room so the water is nice and hot. Plus it's running so much that it really doesn't have a chance to cool down. Maybe I should get one of those blower door tests to seal up leaks around the house....
Thank you!!
Old 06-24-2011, 07:44 PM   #5
An old Tradesmen
The attic fan could be drawing air from the house if there isn't enough vents in the attic for it to draw air from.
Your return ducts may not be sealed properly. And could draw in attic air.
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
Honeywell Visionpro IAQ function 406 ventilation in high humidity ? Charlie123 HVAC 1 05-08-2010 11:19 AM
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
Humidity issues chapx HVAC 8 09-25-2009 04:11 AM
Finished attic humidity? kcrossley2 HVAC 2 08-11-2009 05:06 AM
