Humidity With A/C - HVAC - DIY Chatroom Home Improvement Forum
Old 10-26-2008, 09:58 AM   #1
Whatamess
Question
Humidity with A/C
Does anyone know the approx. max % of humidity that should be present in a home if the A/C is working properly and has been on for two days. Cycling properly. I would think this should be a very low number.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 10-26-2008, 10:47 AM   #2
Assuming the ducts and unit is properly sized, around 40% at a temp of 75%
hvaclover is offline   Reply With Quote
Old 10-26-2008, 10:48 AM   #3
What can I find here?
Winchester's Avatar
Rewards Points: 150
I believe the "comfort zone" for RH is between 40-60% for those months when you use your AC.
This is from my Aprilaire Humidifier Manual
Outside Temp | Recommended RH
+40F | 45%
+30F | 40%
+20F | 35%
+10F | 30%
+0F | 25%
-10F | 20%
-20F | 15%
Winchester is offline   Reply With Quote
Old 10-26-2008, 10:56 AM   #4
This is from my
AprilaireAprilaireAprilaireAprilaireAprilaireAprilaireApril aireAprilaireAprilaireAprilaireAprilaireAprilaireA prilaireAprilaireAprilaireAprilaireAprilaireAprila ireAprilaireAprilaireAprilaireAprilaireAprilaireAp rilaireAprilaireAprilaireAprilaireAprilaireAprilai reAprilaireAprilaireAprilaireAprilaireAprilaireAprilaireAprilaireApril aireAprilaireAprilaireAprilaireAprilaireAprilaireApril aireAprilaireAprilaireAprilaireAprilaireAprilaireA prilaireAprilaireAprilaireAprilaireAprilaireAprila ireAprilaireAprilaireAprilaireAprilaireAprilaireAp rilaireAprilaireAprilaireAprilaireAprilaireAprilai reAprilaireAprilaireAprilaireAprilaireAshraeAprilaireAprilaireAprilaireAprilaireAprilaireApril aireAprilaireAprilaireAprilaireAprilaireAprilaireA prilaireAprilaireAprilaireAprilaireAprilaireAprila ireAprilaireAprilaireAprilaireAprilaireAprilaireAp rilaireAprilaireAprilaireAprilaireAprilaireAprilai reAprilaireAprilaireAprilaireAprilaireAprilaireAprilaireAprilaireApril aireAprilaireAprilaireAprilaireAprilaireAprilaireApril aireAprilaireAprilaireAprilaireAprilaireAprilaireA prilaireAprilaireAprilaireAprilaireAprilaireAprila ireAprilaireAprilaireAprilaireAprilaireAprilaireAp rilaireAprilaireAprilaireAprilaireAprilaireAprilai reAprilaireAprilaireAprilaireAprilaireAprilaireAprilaireAprilaireAprilaireApril aireAprilaireAprilaireAprilaireAprilaireAprilaireA prilaireAprilaireAprilaireAprilaireAprilaireAprila ireAprilaireAprilaireAprilaireAprilaireAprilaireAp rilaireAprilaireAprilaireAprilaireAprilaireAprilai reAprilaireAprilaireAprilaireAprilaireAprilaireAprilaireAprilaireApril aireAprilaireAprilaireAprilaireAprilaireAprilaireApril aireAprilaireAprilaireAprilaireAprilaireAprilaireA prilaireAprilaireAprilaireAprilaireAprilaireAprila ireAprilaireAprilaireAprilaireAprilaireAprilaireAp rilaireAprilaireAprilaireAprilaireAprilaireAprilai reAprilaireAprilaireAprilaireAprilaireAprilaireAprilaireAprilaireAprilaireAprilaireApril aireAprilaireAprilaireAprilaireAprilaireAprilaireA prilaireAprilaireAprilaireAprilaireAprilaireAprila ireAprilaireAprilaireAprilaireAprilaireAprilaireAp rilaireAprilaireAprilaireAprilaireAprilaireAprilai reAprilaireAprilaireAprilaireAprilaireAprilaireAprilaireAprilaireApril aireAprilaireAprilaireAprilaireAprilaireAprilaireApril aireAprilaireAprilaireAprilaireAprilaireAprilaireA prilaireAprilaireAprilaireAprilaireAprilaireAprila ireAprilaireAprilaireAprilaireAprilaireAprilaireAp rilaireAprilaireAprilaireAprilaireAprilaireAprilai reAprilaireAprilaire
Humidifier Manual
+40F | 45%
+30F | 40%
+20F | 35%
+10F | 30%
+0F | 25%
-10F | 2
Ashrae
0F | 15%
Winchester that is a chart for winter humidification. The OP is asking about summer cooling.
The numbers I posted are the inside design temps that an a/c should maintain according to ASHRAE standard and ARI.
Old 10-26-2008, 10:58 AM   #5
LOL you get a cramp in your finger?
Old 10-26-2008, 07:17 PM   #6
Winchester's Avatar
Rewards Points: 150
You don't think I'm aware of that? You mean you don't see temps in the negative zone and run the ac?
Give me a break....I supplied what I've read on the comfort zone (40-60 RH summer) and then gave winter RH as because that's the season most of us are seeing here in the U.S. I was just trying to be informative to RH for the whole year. After all, if the question is what RH should be with the AC who's to say he/she knows what it should be in the winter?
I haven't been around here long but I have certainly noticed how you (hvaclover) like to jump on people's posts. Ease up some, if we're reading the posts we're either interested in the answer or just trying to help.
Old 10-26-2008, 10:27 PM   #7
I am only answering the question that is asked. And this was concerning summer RH not winter humidification.
In summer ac we are DE-humidifying air in summer, removing moisture, not adding it.
Your chart is only accurate for the winter months.
When an a/c is sized it is done so to maintain the DESIGN TEMP AND RH, for indoor conditions which is 75*f @ 40 to 45% RH.
And as far a jumping on posts, if I can expand or correct an inaccuracy I will.
After all it is my job to do that. But you are welcome to your own perceptions.
I just want to help where I can, like we all do.
Old 10-27-2008, 07:36 AM   #8
An old Tradesmen
Rewards Points: 8,234
Depends on the outdoor temps and humidity.
Along with how much infiltration your house has.
And how closely sized your A/C is.
I would say 55%RH is an upper limit, and that would be for milder temp days, that the humidity is high.
45% is a lower limit.
I use 45 as a lower limit. Only because in order to go any lower. Your A/C has to run the blower very slow(or the stat set very low), and loses efficiency trying to remove more mooisture when the humidity is that low.
thermostat and humidity controls for electric attic fans lowlysubaruguy Roofing/Siding 2 09-25-2008 07:32 AM
Darn Humidity javan Painting 13 06-16-2008 01:11 PM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 02:41 PM
*****High Humidity in Basement***** bobbart HVAC 1 06-20-2006 10:43 AM
